Just had my 1971 454 back from my local shop, performing a 4 wheel alignment. When raising the car in the back and grabbing the tire at 12 and 6, there is a significant movement. The question is, are you supposed to stack the shims firmly on both sides of the trailing arm, for the purpose of removing this "end play"? What are the margins here?
All wheel bearings, trailing arm bushings, pivot bolts as well as wheel bearings have been replaced as well.
Are the TA shims in place? Yes they are supposed to be tight on both sides of the TA bushing, there should be no lateral movement on trhe TA pivot end. Sounds like you have some differential yoke wear
You shouldn't be able to remove a shim by hand. That means they are loose enough to fall out! There should be a "cotter pin" thing holding them in place (or something similar) if they are not the stock shims.
Yes, supposed to be a long cotter pin thru the frame and shims to make sure they don't fall out and if you could pull one out then the pivot nut was not tight either
I'd go back to that shop, tell them that you're not satisfied with their work and that they should be expecting a bill from a competent alignment shop.
One of the reasons they put the cotter pin in was to prevent the shims from coming out in the first place. Go back and start asking questions. First question: Have you ever aligned or worked on a C2 or C3 rear suspension? If the answer is yes. Ask them how this could have happened. If they answer no, they you will know why the car was improperly aligned that way. Good luck!
I had that issue, every tine I made a left turn, it sounded like a sledge hammer was hitting the rear wheel well. Scared the heck out of me when it first happened. Added more shims and good to go!
I suspect those guys have never aligned a C3...but were willing to fake it just so they could get the money.
