Crate Engines
Old May 21, 2007 | 04:52 PM
corvetteterry's Avatar
corvetteterry
Default Crate Engines
I am looking for a good crate engine source. 350to 383 around 450hp do any of you have a good reliable source
Old May 21, 2007 | 05:29 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Look in Summit, Jegs, GM Performance, --- any where but eBay.
GM makes a few that fall into that power range and I don't think you can beat them for reliability. Edelbrock makes some too, but I think they are way over priced.
Old May 21, 2007 | 07:50 PM
C3 Stroker's Avatar
C3 Stroker
Here are some good ones...
http://www.amerspeed.com/index.htm
Old May 21, 2007 | 08:17 PM
speedreed8's Avatar
speedreed8
http://www.crateenginedepot.com/stor...y_ID=63&Page=2
Old May 21, 2007 | 08:41 PM
72 LT1's Avatar
72 LT1
Check out Gilbert chevrolet (the old Sallee dealership) they have a line of GM performance engines that they "modify/build up". If your after a hot small block, check out there "Super AFR ZZ4." It puts out 465hp and 440ftlb torque. Not bad for a 350. They have many others as well. Worth a look.
Old May 21, 2007 | 09:03 PM
Duke94's Avatar
Duke94
Here's a couple of companies from posts I saved that got high ratings.
http://forums.corvetteforum.com/show....php?t=1564813
http://forums.corvetteforum.com/show....php?t=1610024
Old May 21, 2007 | 09:55 PM
Crunch-o-Matic's Avatar
Crunch-o-Matic
for 450 hp range I'd go with a stroker motor because it will have better street/driveability maners Otherwise a standard bore and stroke 350 w/ 450hp probably wont "come to life" until you get it above 4000 rpms.
Old May 21, 2007 | 11:28 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I used to have a iron headed 383/465 HP from AR Racing in Virginia and had very good experience with it. I paid $2995 for that engine and ran mid 11's in the 1/4 mile... However, other forum members had bad experience with their engines. I actually bought another engine from them (which was a lot more $) which made the car run in the very low 11's. The only complaint that I'd have about them was that they used a different cam for the build as I requested even though the cam used was very similar in specs...
For me, I really got a lot of engine for the money but their quality seems to vary..
Old May 22, 2007 | 12:59 AM
panic's Avatar
panic
veeery good ones!
i have their 406ci 'brutus' engine 575 hp dinoed 2 years ago, goes like hell beeing always in paradise, never had an iussue since moment 0, just switched up and it was a simphony...more then 5.000 miles on the clock and for some reason it goes faster every day...
Old May 22, 2007 | 02:29 AM
Graemeinvette's Avatar
Graemeinvette
I got mine from the Engine Factory, 4k miles in and very pleased.
www.enginefactory.com
Old May 22, 2007 | 10:25 AM
rudolph schenker's Avatar
rudolph schenker
I have been pleased with enginefactory.com, zz383,450hp turnkey package.
Old May 22, 2007 | 10:33 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Hey man, since you're here in GA, check out www.dixiemailorder.com They are the mail order portion of Wheeler power products in Jacksonville, Fla. I have one of their engines in my '69 Camaro and have been very happy with it. I've also seen on the forum here that alot of people are extremely happy with T&L engines out of North Carolina. I think they are in or around Charlotte. They sell on ebay, but sell outside of there too I believe. Maybe someone will chime in.
Old May 22, 2007 | 04:04 PM
corvetteterry
MAN YOU GUYS ARE GREAT. thanks for all your help.i am building a custom 1978 vetteframe off nothing on this car is stocki will post some pics soon
To Crate Engines
