this cant be right?
May 22, 2007 | 06:40 AM
this cant be right?
driving down highway and punched it (1969 vette)
light doors flipped up and lights came on at about 80 mph?
never knew this happened before?
May 22, 2007 | 07:08 AM
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I think that was an option in 1969.
May 22, 2007 | 07:51 AM
Checkout the vacuum check valve, make sure it works.
May 22, 2007 | 09:01 AM
That's what happens when you jump into hyper-drive
May 22, 2007 | 09:18 AM
Quote:
Originally Posted by
rabiddawg
Popping up is not a surprise - mine does that occasionally - bulbs actually coming on could be a real issue if you didn't pull the H/L switch...
May 22, 2007 | 09:21 AM
once i slowed down under 80 the lights went off and light doors closed?
May 22, 2007 | 09:27 AM
I would like to know
rabiddawg
How did you keep the car straight when you climbed out to see the lights were on?!?!?
I'm assuming you have the fibre optic indicator. Is that right?
May 22, 2007 | 09:45 AM
yes I do but the instrument lights came on so that how I was able to tell the lights came on.
May 22, 2007 | 11:49 AM
May 22, 2007 | 01:12 PM
markbett
Ya it’s for speed
May 22, 2007 | 01:19 PM
From: The reason time exists is so everything doesn't happen at once
BB72
Aim for a plate glass store front to see if there's any reflection.
May 22, 2007 | 01:28 PM
jrzvette
At 80 mph, but make sure you have your safety belt on first.
May 22, 2007 | 02:23 PM
geez ask a question all I get is wise cracks?
May 22, 2007 | 03:10 PM
Weak or bad vac check valve located in the large vac line coming off the rear of the intake. It looks like a pot metal line splitter (1-2 lines) but really functions as a check valve. Could also be a leaking vac can reservoir.
May 22, 2007 | 04:14 PM
Hammerhead Fred
If the dash lights and headlights also came on, as he said happened, then it's not a vacuum leak issue.
Sounds like your headlight switch came on somehow (vibration?). I think that's the only common spot that would (a) turn on the electrical power to the headlights and dash lights circuits and (b) signal the vacuum relays to open the headlight buckets.
May 22, 2007 | 07:57 PM
yeah vacum isnt the issue
but I did go above 80 mph on the way home from work and it did it again?lights popped up @80 and the lights came on again?
very weird if you ask me?
someone said maybe there was an aftermarket gizmo that the previous owner put in to do that cuz all the vacum and lights work properly otherwise.
I did notice a few little black boxes attached to the fuse panel that dont look to be original equiptment.
hmm maybe a james bond car lol.
May 22, 2007 | 11:11 PM
rabiddawg
Well, until this post, you hadn't asked a question.
May 23, 2007 | 09:13 AM
Z-man
Yeah he did.... "Can this be right?" Leaves a lot to the imagination.
Good luck with your lighting problem. One solution is to drive under 80 during the day and over 80 at night.
May 23, 2007 | 09:16 AM
SIXFOOTER
Maybe with all the excitment you forgot you pulled the check valve down
May 23, 2007 | 04:38 PM
My vote is
A bad check valve...thats the 1 into 2 vacuum fitting coming from a engine manifold port.
