77 Door Handle Spring
Old May 23, 2007 | 02:57 PM
SHRKATTK's Avatar
SHRKATTK
Default 77 Door Handle Spring
The drivers door will not open from the outside. Does the handle spring have anything to do w/opening the door, or does it just keep the handle from sagging. I was hoping it might be a quick fix.
Old May 23, 2007 | 03:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sounds like the rod has come off the handle flap. You'll have to pull the trim panel in order to take a look. The spring is not the problem.
Old May 23, 2007 | 06:58 PM
Erik016's Avatar
Erik016
Most likely the rod did come off. My passenger door kept doing that for about a year. Every time I'd fix it ,it would happen again about a month later. Once i got a new clip for it ,I also zip tied it and I haven't had the problem again.
Old May 23, 2007 | 10:56 PM
77Vette4S&J's Avatar
77Vette4S&J
Durango knows a ton about door handles and helped me out a couple of times. Hopefully he will see it and respond.
To 77 Door Handle Spring
