AC delete box available
Old May 23, 2007 | 05:23 PM
Tim H's Avatar
Tim H
Default AC delete box available
I just got mine from American Graffiti.
It was $139 +$18 shipping.
WWW.ACDELETE.COM
You will have to call them and ask for one.
I;ll be putting it on in the coming weeks!!
Old May 23, 2007 | 06:10 PM
Durango_Boy's Avatar
Durango_Boy
WWW.ACDELETE.COM
Let me know how the fit is. I've been curious about and even almost ordered one until just making my own.
Will you have to remove the core to use it or will it allow the USE of the core and heater hoses?
Old May 23, 2007 | 08:48 PM
Tim H's Avatar
Tim H
I have used boxes from this company 2Xs before and they fit pretty good.
You use the heater core thats in the car now, they will come from underneath and have more room to put them where you want.
I'll take pics when I do it, which should be within a couple of week, Im waiting for a fan shroud before I start to tear the engine apart.
Old May 23, 2007 | 11:20 PM
lucky76's Avatar
lucky76
Default Coming Soon 68-82 Y-Body (Corvette)
Do they have it now for Corvettes?
It says "Coming Soon 68-82 Y-Body (Corvette) " on the web page.
Old May 23, 2007 | 11:39 PM
Tim H's Avatar
Tim H
Yes !!!!! mine is sitting in the garage right now, got it yesterday.
Give them a call and tell them what you want.
They said they did a 74.
Old May 24, 2007 | 07:27 AM
Durango_Boy
Pics pics pic...
Old May 24, 2007 | 12:21 PM
markdtn's Avatar
markdtn
That will look so much better than just wacking the lines. I just hate to go to a car show and see a nice car but the a/c box and evaporator are still there but nothing else. To me remove it all or none. Don't leave it half done. My .02
Old May 24, 2007 | 02:09 PM
Tim H's Avatar
Tim H
This box will make it look real real good, and for most they will think its air delete car!
Old May 24, 2007 | 08:25 PM
Older Than Dirt's Avatar
Older Than Dirt
I installed one of these about a week ago. It fit very well and is well made, not cheap and flimsy.
Old May 24, 2007 | 08:34 PM
chris75stingray's Avatar
chris75stingray
that looks good. is that a noise supressor in your picture(the blue can) ? what power wires did you hook that up to?
Old May 24, 2007 | 08:41 PM
Chandler's Avatar
Chandler
That does look good. And yes what is the blue....capacitor?
Old May 24, 2007 | 08:44 PM
Older Than Dirt
Yes, it's a Crane noise and spike suppressor. I'm using it for my Crane HI-6 cd ignition box.
Old May 24, 2007 | 09:24 PM
76 VETTE's Avatar
76 VETTE
How Does The Inside Controls Work And The Fit To The Inner Plenum. Do You Need Different Dash Pads?looks Good
Old May 24, 2007 | 09:53 PM
Older Than Dirt
The only thing I had to do was unbolt the old evaporator-blower box and bolt the new one on. I chose not to remount the fan speed resistors. My fan speed only works on high now which is ok with me. All I need is some occasional defrost and heat. You will have to drill the bolts holes in the new plate. It's very simple to install, just use some patience and be sure to drill the holes in the right spot. Your inside controls work the same as before minus the A/C. I only had one bolt that was on the inside under the dash, very easy to get to.
Old May 25, 2007 | 06:20 AM
Tim H's Avatar
Tim H
Your looking way to deep on this!!!!!!
Old May 25, 2007 | 01:16 PM
76 VETTE's Avatar
76 VETTE
WHAT DO YOU MEAN. I WANT TO KNOW HOW EVERYTHING IS GOING TO COME OUT RIGHT!!!!!
Old May 25, 2007 | 09:14 PM
Tim H's Avatar
Tim H
Well I took the air box off tonite and its a pain in the XXX, tore up the firewall a little.
I tried to fit the box to the firewall and I don't see how its going to fit without alot of cutting and fitting??????
My other two cars I used them on worked really good.
To AC delete box available
Old May 26, 2007 | 07:32 PM
Older Than Dirt
Sorry to hear that. I didn't have to cut anything, only drill some holes in the plate. It fit perfectly and I was very impressed that it did. Not many aftermarket parts will.
Old May 26, 2007 | 08:39 PM
Durango_Boy
Here's my custom A/C delete plate. No, I cannot use the heater lines any more but I didn't plan to. I had already cut the heater core out of the loop.
Old May 27, 2007 | 09:47 PM
Enersis's Avatar
Enersis
Just glass it
