Help - brake fluid ??
Old May 23, 2007 | 06:12 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Default Help - brake fluid ??
I don't know what kind of brake fluid is in my '68, I need to add and don't want to mess up.
The fluid that is in it is clear but doesn't seem to have the typical brake fluid smell.
I have some Castrol LMA and also some DOT 5 fluid, the Castrol is clear and smells, the DOT 5 has a purplish tinge and no smell.
Anyway to tell what it is? A search didn't come up with a definite answer.
Thanks!
Old May 23, 2007 | 06:28 PM
Roughrider's Avatar
Roughrider
Do not under any circumstances mix DOT 5 with DOT 3 or 4 mineral based brake fluid. It will make a cloudy mess and give you a very mushy pedal.
It sounds like you have DOT 3 or 4 in it now. If you're not sure what you have...have your brake system completely flushed and dried before adding whatever fluid you want to keep in it.
Your car would have originally come with DOT 3. I would stick with that. The only way I would change to DOT 5 synthetic would be if the entire brake system...metal and rubber lines, seals, etc., were all replaced. Synthetic has its advantages, especially in a car not regularly driven, but it can create problems if not careful in using it.
Old May 23, 2007 | 06:40 PM
...Roger...'s Avatar
...Roger...
Rub some fluid between your fingers-the dot5 will feel slicker than regular fluid.Probably not recomended but I touch it to the tip of my tongue-reg. is bitter --synthetic is almost tasteless---spit spit spit
Old May 23, 2007 | 09:41 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I usually flush my brake systems with DOT4 fluid. I usually flush with clear DOT4, then fill with ATE Super Blue. It is real easy to tell when it is done.
Old May 24, 2007 | 12:07 AM
jake1's Avatar
jake1
Dot 3, had to replace intire system due to wrong fluid. calipars, master cyl.
Old May 24, 2007 | 05:18 AM
ffas23's Avatar
ffas23
Get a clean empty bottle the size of a Baby food bottle or what ever small size bottle you can find. Open up your master cylinder and take some fluid out to fill the baby bottle a quarter of the way up. Now take some water of the same amount and put it in the same bottle with your brake fluid. Put the cap on the bottle. Shake it up and come back later on to view it. Say maybe an hour. If the brake fluid stays mixed with the water you have Dot 3 brake fluid in your master cylinder. If the brake fluid floats on top of the water you have Dot 5 Silicone brake fluid in your master cylinder.
Old May 24, 2007 | 10:12 AM
supercalvin's Avatar
supercalvin
Gotta love the old school method for testing auto fluids.
I wonder how they effect my cholestorol levels.
Old May 24, 2007 | 02:52 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Put a dab of fluid on a painted surface(NO, not on the Vette!). Dot3 will soften the paint, dot5 silicone won't.
Old May 24, 2007 | 08:07 PM
Red70vette's Avatar
Red70vette
ffas23 is right on the money. Silicone(DOT5) repels water. DOT 3 or 4 mixes with water. Easy test. Much better than the taste test. If you have been taste testing for many years you can no longer taste anything anyway.
To Help - brake fluid ??
