t-top storage
Old May 24, 2007 | 10:13 PM
doug9208's Avatar
doug9208
Default t-top storage
anybody know how to put t=tops in the luggage rack on a C3?
Old May 24, 2007 | 10:21 PM
randommj's Avatar
randommj
if u mean "on" the luggage rack? then u should hav a bracket in the middle of the bracket that they lay on, and 2 straps that hold them down
now "in" you "trunk" the just go in there 90* of how they fit on the car, just one on top of the other
Miles
Old May 24, 2007 | 10:28 PM
doug9208's Avatar
doug9208
sorry I do mean on the rack. I've got the brackets and figured out they both mount to the center of the rack but no idea of which one goes which direction. Any pics of a set installed ?
Old May 24, 2007 | 10:34 PM
randommj's Avatar
randommj
im pretty sure that it dosent matter, it just puts a slight gap between them yle you drive so they dont clash, ill try to post a pic tonight, justa sec
Miles
Old May 24, 2007 | 10:39 PM
randommj's Avatar
randommj
here ya r!
you just slip the front one up how ever much forward you want it, and strap em' down
Miles
Old May 25, 2007 | 03:29 PM
doug9208's Avatar
doug9208
Miles - thanks for the pic. I had guessed the right direction of the brackets just wasn't sure about the sliding forward part. I guess that makes sense.
Old May 25, 2007 | 10:03 PM
ksbunting's Avatar
ksbunting
RandomMj,
What is that emblem in the middle of your rear window?
Shrine?
Kurt
Old Feb 23, 2008 | 05:24 PM
darebren's Avatar
darebren
re; the brackets, the one closest to the window needs to be the bracket that is angled, and angled towards the window, hooked to the luggage rack as far up the bar to the window as possible, the other brackets goes in between the 2 lower tabs on the lower side of the rack... then the tabs in the side of the t top that fit into the roof holes, will slip into the sides of the bracket in those holes and it holds them down better. the strap hooks onto the rack under the t tops and goes up around them. i found that the strap has a metal buckle that will chip the t tops so it's best to use some elctrical tape, or cut a black sock to slip over the buckle.
if you just put the brackets anywhere in the middle, it won't hold the tops securely because they wont fit into the mounting holes in the bracket.
Old Feb 24, 2008 | 09:01 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Here is a pic of a rack designed to use with the brackets. The small pins locate the brackets and there are also a set of pins on each outer bar to locate the hold down strap.
[IMG][/IMG]
To t-top storage
