numbers info
Old May 25, 2007 | 09:54 PM
rstmeredZ's Avatar
rstmeredZ
Default numbers info
I need help decoding engine #s on VIN 194679S718939
12B705283 T06C30KD on front of block
3970014 on rear
Any info would help! Car is a 1969 vert 4 spd w/ hardtop
Gary
Any links on tracing or tracking would help me greatly!
Old May 26, 2007 | 08:22 AM
rstmeredZ's Avatar
rstmeredZ
TTT
Where can I go to run these #s?
Old May 26, 2007 | 12:17 PM
avner's Avatar
avner
Engine Casting #:3970014 late 72 & early 73 (350ci, 200hp or 255hp) 12B705283 = engine ID # I don't think it' corvette #.
Try this link:
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old May 26, 2007 | 02:22 PM
Duke94's Avatar
Duke94
Originally Posted by rstmeredZ
TTT
Try this too.
http://www.corvetteactioncenter.com/...arch/index.php
Old May 26, 2007 | 09:23 PM
rstmeredZ's Avatar
rstmeredZ
Originally Posted by FrankVincent
3970014 is a Tonawonda block cast in 1972. You should be able to find a casting date on the rear passenger side of the block.
T06C30KD is very strange ...
T=Tonawonda(that part is the easy one!)
The next 4 digits will represent a month/date sequence, so that 'C' stuck right in the middle does not belong. Is that a typo?? Otherwise, 0630 is June 30th.
KD= the only 2 KD codes I can find are for a 1956 small block and 1969 big block. Again, is there a typo here?? If not, the whole thing may just be a poorly researched restamp ... ??? I say that because the 'B' in the 12B705283 indicates a Baltimore Plant location which made the Chevelle in 1969. So maybe the original Chevelle BBC engine 'crashed&burned', and this was a replacement block ... ??
1969 - 396 - Chevelle - 375 - L78 - Manual - 4Brl - Solid cam,Holley
1956 - 265 - Truck - 155 - Manual - 2Brl - Air Brakes, Hydra
Maybe check the numbers again and confirm .... ??
(definitely not a 1969 Corvette engine though!!!)
No typo, I took pics. I suspected, as did the dealer, that the engine was incorrect. I was curious about the actual origin though. Oh yeah, it's a small block so the BBC info wouldn't apply. Hmmm.
To numbers info
