DeWitts Drain Petcock.
Old May 27, 2007 | 07:16 PM
Durango_Boy's Avatar
Durango_Boy
Default DeWitts Drain Petcock.
So I finally installed my beautiful DeWitts direct fit aluminum radiator in my 1977. Everything went well. I replaced all the core support seals, and have plans and materials for the upper and lower seals.
I was leaning over the fender installing the lower rad hose, and my face's position put my line of sight run down the radiator filler neck. You know what I saw?
The day lit ground under the front of the car. I did a double take, because I could see the ground under the front of the car by looking down into the radiator.
It occurred to me that this was the location for the drain petcock. My first thought was that this could have been included with the radiator. My next thought was how much of a pain it was gonna be to measure and install it when I could have done it before the rad went in.
Then I began to wonder how many guys out there installed their DeWitts and started to fill with fluid only to see it all flood out on the floor. While funny, that would be a waste of distilled water and coolant.
So, share your stories and if you know off hand what size that drain petcock is, please enlighten me.
Thanks.
Old May 27, 2007 | 07:28 PM
72LS1Vette's Avatar
72LS1Vette
I'm not sure that I remember this correctly, but I had to buy a new petcock for my old radiator befire I bought the Dewitt's. I just took the old one to Autozone and had no trouble getting a replacement. If I did have to install a petcock on the Dewitt's it was most likely the replacement that I removed from the old radiator. At worst you could bring the radiator into the store and find a petcock that will fit.
Dewitt's is probably closed for the weekend but Tom often reads the forum so maybe he will respond with the correct size.
Rick B.
Old May 27, 2007 | 07:35 PM
Durango_Boy
The crap part here is someone stole my old radiator out from in front of my house before I had a chance to take off the petcock.
I wish I could have seen that punk running off with that old radiator so I could yell...
"It's got a huge hole in it, good luck with it.."
Old May 27, 2007 | 07:37 PM
blueray72's Avatar
blueray72
My Dewitt's rad came with a drain.
Old May 27, 2007 | 07:46 PM
coinwasher's Avatar
coinwasher
Hey D B check the inside of the box, mine was taped to the inside.
Old May 27, 2007 | 07:48 PM
Durango_Boy
Guess what my old radiator was in while it was sitting in front of my house.
Old May 27, 2007 | 08:34 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I believe the threads are 1/4" NPT, any auto suppy store will sell those petcocks. I also believe Home Depot sells them, most air compressors use the same size petcocks. On a related note, I installed a 90* fitting in the bottom of the rad, then a 1.5" nipple, and then the petcock, which makes it much easier to get to when you are draining the rad and makes less mess because it is not draining onto the crossmember.
EDIT: changed 3/8" NPT to 1/4" NPT after checking.
Old May 27, 2007 | 08:37 PM
Durango_Boy
Originally Posted by 7t2vette
I believe the threads are 3/8" NPT, any auto suppy store will sell those petcocks. I also believe Home Depot sells them, most air compressors use the same size petcocks. On a related note, I installed a 90* fitting in the bottom of the rad, then a 1.5" nipple, and then the petcock, which makes it much easier to get to when you are draining the rad and makes less mess because it is not draining onto the crossmember.
Awesome idea bud. I was thinking along the same lines and was going to do that to the block drain plugs as well. That'll make flushing every spring easier.
Old May 27, 2007 | 08:40 PM
7t2vette's Avatar
7t2vette
Yep, replaced the block plugs with petcocks too. It sure makes draining the entire cooling system easier.
Old May 27, 2007 | 08:55 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
All petcocks are 1/4" npt and each Direct Fit model is sapposed to have one included. We pack the petcock into the spacer box, which should be the first thing you see when openning the box. We pack it loose because 90% of our UPS damage was done to the petcocks sticking out the bottom. We figured if we packed them loose, they could no longer damage the valve or the radiator.
Old May 27, 2007 | 09:03 PM
rosslato's Avatar
rosslato
I'm guilty also but didn't find out till i saw dexcool pouring out the bottom
Old May 27, 2007 | 09:04 PM
Durango_Boy
Hey Tom. I'm glad you're searching the forum this weekend...I figured I would just email you Tuesday.
First let me say that radiator is AWESOME. The quality and workmanship that went into that product is spectacular. I'm very proud to have a DeWitt radiator in my Corvette Project.
Now, I admit I opened the box without thoroughly checking all the packing so it's entirely possible it was taken with the box.
So yep, when I took out the old rad, I slipped it into that box, and set it out front of my house. Later that afternoon, yesterday, I went out and the box and radiator was gone. No big deal, since the old rad had a big hole in it, but it seems the petcock is gone too.
Thanks for the info and checking in.
Old May 27, 2007 | 09:15 PM
oregonsharkman's Avatar
oregonsharkman
Mine too.already in the Radiator............or I would have done the same thing
Old May 27, 2007 | 09:29 PM
Babypig's Avatar
Babypig
hey mr.dewitt, i just got my A69A and didn't open yet, what is my petcock situation. TD in NY.
Old May 27, 2007 | 10:24 PM
VETTEVIC's Avatar
VETTEVIC
Mine too.
Old May 27, 2007 | 11:30 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i just got mine with the dual fans and it came with one in the box.
Old May 27, 2007 | 11:37 PM
blueray72's Avatar
blueray72
I would call him.
To DeWitts Drain Petcock.
Old May 28, 2007 | 08:12 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Everyone gets one! Open the box, it should be right there.
Old May 28, 2007 | 02:16 PM
Durango_Boy
Okay, picked up a drain petcock at Lowes. Installed in seconds and was cheap.
At least the thief got a free petcock.
Old Jun 12, 2007 | 02:58 PM
mck77's Avatar
mck77
1st Gear
DB - did you buy your Dewitts locally or have it shipped directly?
I'm in Kingston, Ontario, Canada.
(Mr.Dewitt - your 'sales@dewitts.com' bounces back.)
