T5 woes
Old May 28, 2007 | 11:42 AM
lowbuck72's Avatar
lowbuck72
Default T5 woes
I put a world class T5 in my '72 and it's been bullet proof so far, however, a few years ago I put a $300 used non world class in my '55 shoebox, took it out for a spin yesterday... Smoked them all through first, most of second, but when I shifted to third, blammo, then nothing! I nursed it home in second gear and parked it. I guess I'm going transmission shopping. I may try and fix the NWC, downloaded a manual, but I think the WC is the way to go, and they're not too expensive.
Old May 28, 2007 | 01:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You have to be careful shifting any T5 into third. It's the weak link in the system. A third-gear powershift will blow the tranny up every time.
Old May 28, 2007 | 09:27 PM
lowbuck72's Avatar
lowbuck72
Now you tell me:o
Old May 28, 2007 | 10:07 PM
hosspowerinc's Avatar
hosspowerinc
Especially on the NWC. They are easy to rebuild. Just throw another 3rd in there and take it easy.
Old May 28, 2007 | 10:33 PM
Hotrod406's Avatar
Hotrod406
I think taking it easy is the key on any T5. The WC versions are only rated to 300 lb ft. Great for a cruiser/driver, bad for a hotrod.
Old May 28, 2007 | 10:38 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
I killed a T-5 with a 305 in my old Formula.
I had 1-2 5.
Old May 28, 2007 | 10:39 PM
Ironcross's Avatar
Ironcross
Originally Posted by lowbuck72
Now you tell me:o
You didn`t ask!
Old May 29, 2007 | 01:02 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Norval ran one behind a big block. Don't shift like a maniac, and they stay together.
Also, several of the Fjord T5s were rated for well over 300 ft-lbs of torque.
Now you tell me:o
It's been mentioned before...
Old May 29, 2007 | 01:32 AM
Retro78's Avatar
Retro78
Norval's big block is also blown. I also run a T5. You had the worst combination for failure, power shifting, into 3rd, on a non WC T5. The 94-95 Ford T5's are the strongest.
http://www.therangerstation.com/tech_library/T5ID.htm
The good news for you is that rebuilding them or buying a good used one is easy.
Old May 29, 2007 | 09:20 PM
lowbuck72's Avatar
lowbuck72
I went through the T5 manual I download for free on ebay, and it looks like it's pretty easy to rebuild. I've been drivin' that trans pretty hard these last few years, broke'm loose in third more times than I can count, lot o' fun though...
Old May 30, 2007 | 04:48 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sounds like it held up longer than it had any right to.
To T5 woes
