The horn did not work when I purchased it. I found the horn contact spring assembly was missing. I was able to purchase the parts (spring, pin, insulator). The pin or insulator is a bayonet connection to a plastic piece in the hub, as soon as I secured it, pop the plastic piece broke. I have not been able to find the plastic piece. I would rather but just the plastic part rather then the hub. Any ideas?
I just noticed that the little white tube is crscked on mine. Is it really necessary that I replce it. It is just broked a little at the top where it sticks out? Unless it is an easy and cheap fix.
If your horn works and the spring and pin are connected, I would think you good to go. On mine the pin would not stay in the tube.
