How to open door with stuck latch
The passenger side door latch hasn't been working right for some time. I found that it would jam every time I used the inside locking mechanism. I unhooked this and only used the key. A couple of weeks back, that stopped working. The door was locked and shut so at least I could drive it.
I managed to get the door panel off from the inside. Prying pretty hard, I am still not able to free the lock. I don't mind replacing the latch, but i can't even get the door open and can't get the latch out without opening it.
Any ideas? I'm starting to have thoughts of cut off wheels and that's usually a good time to stop and post.
Don't cut off anything. It's very easy. You need a long flat head screw driver and a flashlight. Place the flat tip on the part of the mechanism being pointed to. It's right up against the bulkhead. You'll see it. Get the screw driver on it, and push down firmly. It may slip off once or twice but once you get a good contact and push it down the door will pop open.
Thumbs (05-13-2019)
Thanks for the fast post DB, but I think it must be for a different year. The jammed lock is on my 81 and It looks somewhat different. I'll try to take a decent pic and post it.
TheCorvetteBen
think the outside door handle rod is still pushed down . handle will pop up but rod is still loading the latch and WILL not unlock till returned to neutral
try lubing pivot at bottom of door handle and force outside door handle rod back up . then unlock door it will open
Thanks again guys.
I had to resurrect this thread. Thanks for the info, I tried to open it for an hour. 3 minutes after reading this I was standing in front of an open door. Durango Boy/ Corvette Forum rock!
Any tips/tricks to removing the door panel from a 75' when the door is locked closed with this problem? I have the screws out (bottom three plus door pull, the rest are busted (I thinK) from previous owner), but the interior door handle is a problem. There doesn't seem to be any room to manuver the panel forward to clear the door handle. Any help will be appreciated!
can't get door to un lock
I put new outside handle on rhs of car, door opened fine with new handle tried locking door it locked but would not unlock seems like it is not throwing unlock lever far enough can;t budge it door is shut but will not open at least door panel is off any suggestions
You have to adjust the outer handle linkage so there is no tension on the mechanism when the handle is all the way up. Disconnect the outer handle and the lock should work again and you can open the door.
okay I'll try it . Do I have to remove hande again or just linkage that back nut is a pain in the butt to start thanks again
To open the locked door...first of all, open the door that you can still open. Take of the interior panel. Now with the door open, and the panel off, practice opening this door where you can see more about what you're doing. This is what I did for my 68 and 70 !!! I've had a locked door hit on each car.
Once a door latch has locked up on you...think about replacing it. Up until a few years ago, new 69 to 82 latches were still available..still available? Need a 68 latch...this is a different world. The interior levers in these latches are 0.070 inches thick of soft steel, once one gets bent or deformed you've got to start thinking about getting rid of it. If it jams once, it'll most likely jamb again.'
