Dash pad installation
Old Jun 5, 2007 | 07:08 AM
Localbulldog's Avatar
Localbulldog
Default Dash pad installation
I tried search but I couldn't find anything on the procedure to remove and replace the upper dash pad. Thought I saw it awhile back but oh well.
Can someone help me out with some instruction please ? 1976 coupe
Old Jun 5, 2007 | 08:04 AM
...Roger...'s Avatar
...Roger...
Remove all moldings around windshield and screws along front of dash.Lift dash pad flex slightly and remove.
Old Jun 5, 2007 | 08:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Wait one. There is probably a bolt or two underneath the pad holding it to the reinforcement bar provided a previous owner didn't leave them out at some point in the past. Remove the passenger's side lower dash pad and you will probably see them.
Old Jun 5, 2007 | 09:41 AM
82MDVette's Avatar
82MDVette
But do not forget, the pad has two clips on the underside near the windshield. The clip retainers are held on with a machine screw with a small hex nut head. Loosen the hex nut on each clip and slide the dash back towards you to release it.
Old Jun 5, 2007 | 12:22 PM
...Roger...
Oops Mikes right.Sorry ! The 2 screws are at the ends of the defroster duct grill and then back towards the rear of car about an inch.There are also 3 screws coming up through the center cluster at the wiper switch.You might be able to get to the 2 screws Mike mentioned by removing the wiper switch and center duct assembly.
Old Jun 5, 2007 | 04:23 PM
Localbulldog
Thanks guys!
Old Jun 5, 2007 | 08:29 PM
VettePekka's Avatar
VettePekka
Warm the dash pad w/ hairdryer, it bends easier...makes the removal less painfull and you'll have a better change to get it out w/o cracking it.
Cheers,
pete
To Dash pad installation
