What's the Goop...
Old Jun 5, 2007 | 05:44 PM
Witz's Avatar
Witz
Default What's the Goop...
That is used to seal up areas on the firewall - like around the steering column... seems like some sort of flexible putty?? Where do I get it?
Thanks!
Old Jun 5, 2007 | 06:28 PM
NHvette's Avatar
NHvette
It is asphalt tar ... scrape it all away and use a nice urethane roof sealant to seal it back up.
The one on the bottom is what I used. "hardens" to a nice rubbery texture after a few days.
Smooth out the bead with a rubber glove and some lacquer thinner.
Old Jun 5, 2007 | 07:47 PM
1stC3Vette's Avatar
1stC3Vette
Good idea! I used some window sealant butyl tape. Rather expensive, but does a nice job.
Good luck,
Dino
Old Jun 6, 2007 | 04:59 PM
Witz's Avatar
Witz
Never would have thought of that - thanks!
Old Jun 6, 2007 | 08:03 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
also check out the eastwood company, they have a 3m flexible srip caulk the does the job nicely
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
cheers
To What's the Goop...
