71 kick panel speakers
Old Jun 7, 2007 | 11:25 PM
nutseynut7's Avatar
nutseynut7
Default 71 kick panel speakers
Just want to put a set of speakers in kick panel There are no speakers in dash.Have stock radio put on new antenna and cable it plays ok, but when you turn it louder the cheap pioneer speakers crack, What size do I need that will bolt in, and what do you reccomend Thanks
Old Jun 8, 2007 | 07:27 AM
Durango_Boy's Avatar
Durango_Boy
Nutseynut -
Where are the cracking speakers located?
You need nice speakers and you need an amp to run them.
That cracking is a couple of things. Maybe the speaker is getting frequencies it's not designed to handle. Also, the head units is working to hard to move the cones back and forth and the cracking might be clipping.
Either way, new speakers will not solve the issue, nor will location. A new head unit would be first in line, but the RMS watts per line won't improve a whole lot. It'll be better though.
On top of that, you could mount a small 2 channel amp, a nice set of coax or component speakers, and really enjoy the sounds heard with that setup.
ajrothm's Avatar
ajrothm
4x6s or 5.25s will fit in the kicks. If you are running a factory radio, I would just buy the lowest end replacement speakers from a decent company, like pioneer. None of them are going to sound good anyway when the volume is turned up. I had 5.25s pioneers, I installed brand new, running them off of a cd player and after a month I pulled them out, installed a good componet set of 5.25s with an amp and a sub woofer. Thats the only way you get any decent sound out of these things.
Old Jun 8, 2007 | 08:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
4x10s will mount behind the kick panels. Stock location for the 68 and 69 models.
Old Jun 8, 2007 | 03:16 PM
nutseynut7's Avatar
nutseynut7
g0t a set of 10ohm speakers but they have to be soldered on will let you know how they work, they are replacements for 78 on up
Old Jun 21, 2007 | 09:58 PM
1971Coupe's Avatar
1971Coupe
I just removed my speakers from my kick panels, Bubba did a shiyt job.
Sounds much better with just the rears speakers Bubba also installed.
They were 6 x 3.5 Radio Shack ones. .....probably garbage.
To 71 kick panel speakers
