Seal under heater core?
Old Jun 8, 2007 | 03:43 AM
jjl's Avatar
jjl
Default Seal under heater core?
I am just in the process of putting back the heater in my 73 (no AC).
The assembly manual is not clear in how this goes together, but the heater core just sits there with nothing holding it in place apart from the hoses when they are connected.. I think that is should at least be sitting on a seal of some sort, both to stop it rattling and also to stop air leaks around the side of it.
Does anyone have any thoughts on this and what have you done to address it, if anything.
Thanks in advance for any help.
Jeremy
Old Jun 8, 2007 | 05:31 AM
Vesa's Avatar
Vesa
Jeremy
-73 AC version has 2 very small "bolts" in the middle holding a bracket...
Old Jun 8, 2007 | 07:26 AM
jjl's Avatar
jjl
Yes, there are two small bolts and a bracket, but these do not really hold the heater core in place. I am more interested in what is "under" the core. The core can still move around even with the bracket in place and it will subsequently rub against the heater "box" that surrounds it. I do not think that is how it should be, with the heater core just floating in space.
Jeremy
Old Jun 8, 2007 | 08:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...there are two small bolts and a bracket, but these do not really hold the heater core in place....The core can still move around even with the bracket in place...
Core should not move. Are you sure you have the correct core. AC and non-AC are different.
Old Jun 8, 2007 | 10:26 AM
Red 69's Avatar
Red 69
Jeremy
Jeremy, I will assume the 73 non AC heater core and box is the same as my 69. On that assumption, the heater core is held in place by a small bracket on the passengers side of the core. If my memory serves me, the bracket is held to the core with two screws. The bracket has two small clips that secure it to a retainer in the box, it clips on. I remember it was in a tight spot and difficult working on the blind. The bracket that screws to the core is about 2 inches square, but this is going on my memory. I rebuild my heater box about 10 years ago.
The box seals on the firewall gasket on the inside and a foam seal on the fan motor housing on the engine side. The original firewall gasket is made of wax and jute. If you do not have one there, you can make your own from other materials if you are not building NCRS correct.
Old Jun 9, 2007 | 02:38 AM
jjl's Avatar
jjl
Red,
I have no real interest in NCRS ideals. I just like things to work well and not be likely to cause issues down the road.
My core can be removed without removing the small bracket that is on the left side. The core can be moved left to right etc and is not a snug fit. It is probably correct, but just seems wrong. I have posted two pics, one with the core and another with the empty heater box. I figure there should be a seal where I have drawn (badly) the red arrows. This would also cushion the heater core and not have it sitting on bare steel. I have replaced the rubber seal on the flap under the core as I see lots of posts regarding heat issues for these cars and where I live the last thing I want is more heat.
Old Jun 9, 2007 | 08:52 AM
...Roger...'s Avatar
...Roger...
Your missing the retaining strap end opposite the inlet tubes.
To Seal under heater core?
