Tire Foam
Old Jun 8, 2007 | 06:18 PM
77vetter's Avatar
77vetter
Default Tire Foam
What does everyone use on their tires? Some of the pictures posted here makes the tires look like they are dripping wet. I have tried Armor All Tire Foam, but not real happy with the look. Also, it flies off the tires and on to the paint when going down the road. I have let it set and then wipe off excess but then it doesn't look as good.
TIA
Old Jun 8, 2007 | 06:21 PM
Durango_Boy's Avatar
Durango_Boy
Black Magic Tire Wet Foam.
Nuff said.
(It's a single foaming spray application that goes on once, and in five minutes or less you have a perfect looking sidewall. You don't have to wipe it off and it comes right off the rims if you over spray.
Total time? 1 minute, 15 seconds per wheel.)
Autozone and Oreilly are know to carry it.
Old Jun 8, 2007 | 06:26 PM
Roughrider's Avatar
Roughrider
There are a lot of brands on the market...some give the tires a glassy shine and some don't.
I use Vinyl and Rubber Dressing from Griot's Garage. I put it on a curved applicator made for the purpose (bought at Wal Mart) and run it around the tires...doing it that way doesn't get overspray everywhere. It gives the tires a nice, even non-glossy sheen. Griot's has some of the best car care products I've used...some are a bit pricey, but really only in comparison to products that Wal Mart sells.
Old Jun 8, 2007 | 07:16 PM
77vetter's Avatar
77vetter
I would like to try something that gives that wet, glossy shine - is that what the Black Magic Tire Wet foam does?
Old Jun 8, 2007 | 07:33 PM
mod81's Avatar
mod81
first...make sure you scrub the sidewalls...Secondly...NO FOAM it all sucks compared to the good sprays, and sponge applied dressings. I recommend armor all extreme shine. it has nozzle settings for low profile tires too. also...I have found that letting it sit on the tire for about 2 minutes then lightly wiping it down with a tire sponge works really good, it keeps the sling from happening without taking the shine off!
Old Jun 10, 2007 | 08:45 PM
Durango_Boy
Yes. I used to use spray applications with the sponge and once I tried this new foam I will never go back. Black Magic foam is the best I have every used.
Old Jun 10, 2007 | 08:53 PM
Glassbowtie77's Avatar
Glassbowtie77
Mequiar's Endurance Tire gel.
Old Jun 10, 2007 | 09:51 PM
trw's Avatar
trw
Pledge in the spray bottle.
To Tire Foam
