OT automatic shifter question
Old Jun 9, 2007 | 10:58 PM
toyvet1's Avatar
toyvet1
Default OT automatic shifter question
I am trying to get a Hurst V-Matic working on a 1968 Camaro. I am having a problem with the netural saftey switch. It is wired with two purple wires to the shifter netural switch. I get nothing when I turn the key. If I bypass the switch by connecting the two purple wires the car will start but no saftey swirch. I am gettin 11.47 volts to the switch but only 8.5 volts out of the switch. I am thinking maybe to much power for a micro switch??? Any ideas..
Old Jun 9, 2007 | 11:07 PM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like the switch may be dad. Usually a microswitch should be good for at least 10 amps and that start circuit won't be anything like that.
Old Jun 10, 2007 | 09:34 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sounds to me like the switch is either not aligned properly or is broken,can you see any adjustment screws onthe switch?
Old Jun 10, 2007 | 09:10 PM
toyvet1's Avatar
toyvet1
No I dont see any adjustment screws. Im thinking the switch is bad. Ill order a new one this week....
To OT automatic shifter question
