Cutting A Large Hole
Old Jun 11, 2007 | 01:13 AM
stinger12's Avatar
stinger12
Default Cutting A Large Hole
How can I cut a 5 inch hole in sheet metal?
Old Jun 11, 2007 | 01:29 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Sawzall
Jigsaw
Torch
Snips
Hole Saw
Cut off wheel
Air Hammer
Old Jun 11, 2007 | 07:24 AM
BlkBird's Avatar
BlkBird
Assuming you want a perfectly round hole a hole saw would be the best choice if you can find one that large. Other than that, drawing out the circle and using any of the above mentioned methods would work fine.
Old Jun 11, 2007 | 09:37 AM
gdm78vette's Avatar
gdm78vette
If the sheet metal isn't that thick then a Dremal with the circle cutting guide would work and get you a pretty even hole.
Old Jun 11, 2007 | 01:07 PM
hosspowerinc's Avatar
hosspowerinc
#1 choice would be a hole saw. It would take a few seconds and they are cheap. #2 would be a jigsaw. They are pretty easy to keep on a line if you go slow.
Old Jun 11, 2007 | 02:54 PM
Hvymtlc5's Avatar
Hvymtlc5
hand nibblers do a good job. Would be perfect for a 5 inch hole if the tin isn't too thick.
To Cutting A Large Hole
