Bench test a 68 Wiper motor?
Old Jun 11, 2007 | 09:30 AM
ddejonge4's Avatar
ddejonge4
3rd Gear
Default Bench test a 68 Wiper motor?
Hello all, I have a 1968 vert that the wipers have not worked for the 5 years that I have owned it. Previous owner had the wiper motor hot wired. He would manually open the wiper door, open the hood, and plug in a hot 12V to one of the connectors, and let them run. I tore out his rigging, went through the entire wire harness, made sure all connection were correct. switch is o.k. relay o.k. wiper door limit switch o.k Not sure where to go next. I do need to verify the motor has a sufficient ground, but beyond that, does anybody know how to bench test the actual motor? (there are a lot of wires going into that thing) I guess I'll have to do a deep dive into the wiring diagram to see what actually feeds what. Let me know if anyone has had similar issues. Thanks!
Old Jun 11, 2007 | 06:26 PM
crf311's Avatar
crf311
make sure the ground wire is connected.
Old Jun 11, 2007 | 07:32 PM
Hammerhead Fred's Avatar
Hammerhead Fred
http://forums.corvetteforum.com/show...ht=wiper+bench
Old Jun 11, 2007 | 11:42 PM
682XLR8's Avatar
682XLR8
[IMG][/IMG]
Here's what a resto shop sent me for my motor. Give it a shot
When the wiper motor is installed, make sure the motor case is grounded and the **** under the steering column is grounded also
Old Jun 12, 2007 | 11:18 AM
ddejonge4's Avatar
ddejonge4
3rd Gear
Great input! The instruction sheet is awesome
Thanks guys.
Old Jun 12, 2007 | 03:26 PM
682XLR8's Avatar
682XLR8
Let us know how it works out
Old Jun 12, 2007 | 08:38 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Also the switch under the steering column lets the wipers stop on the windshield. Make sure it is not in the stop position or the wiper will not work.
Old Jun 13, 2007 | 09:30 AM
ddejonge4's Avatar
ddejonge4
3rd Gear
Thanks, will do. I hope to get some time this weekend to check it out. (unless I go to Bloominton Gold)
To Bench test a 68 Wiper motor?
