is this to hot?
Old Jun 11, 2007 | 10:23 PM
gvrabac's Avatar
gvrabac
Default is this to hot?
hey guys,
just put in a autometer temperature gauge, and the temperature is reading 218. My original unit was reading 190. Any idea's why there is such a difference. Is this to hot?
Old Jun 11, 2007 | 10:37 PM
swtato's Avatar
swtato
St. Jude Donor '05
Originally Posted by gvrabac
hey guys,
Sorry I could not resist!
I cannot explain the difference in temp but you might want to chec the sending unit. I replaced mine and it dropped the temp bac to a normal range.
Old Jun 11, 2007 | 10:43 PM
gator79's Avatar
gator79
get an IR temp gun, factory gauges can be way off. you can pick one up for about $50 they have lots of other uses besides automotive
Old Jun 11, 2007 | 11:13 PM
fronzo's Avatar
fronzo
Old Jun 12, 2007 | 03:30 PM
Stewart's74's Avatar
Stewart's74
Like Cooking on the Grill!
Old Jun 12, 2007 | 03:47 PM
Z-man's Avatar
Z-man
hey guys,
218 won't hurt for a little while, but unless something else changed, that's probably an incorrect reading. If you just replaced the gauge and there is a 30 degree difference, it's probably because the gauge isn't calibrated for use with your sensor.
Old Jun 12, 2007 | 03:50 PM
ajrothm's Avatar
ajrothm
Its still not completely accurate using a temp gun either because it measures surface temps, not water temps. You can get MANY different readings when testing with the IR gun. I bought one last week for this very use and I was getting varying temps. Anywhere from 240* to 180* depending on where I measured. Even measuring the factory temp gauge sending unit in the head read 240*. The thermostat housing was the closest to accurate temps but it was still off.
I ended up buying a good mechanical water temp gauge, I hid the gauge behind my console radio access plates. Then if I need to see it, I can just pull it out as its not mounted and the cord is long. I can pull it all the way to the seat if I need to. I really just wanted it to compare to my factory gauge. At the low temps, my factory gauge reads WAY colder then the mechanical. At regular operating temps(180-190) they are about 5* apart(oem gauge reads cooler), but at higher temps, like 205-210*, the factory gauge is 10-15* colder as suspected.
Old Jun 12, 2007 | 10:26 PM
clintwilson's Avatar
clintwilson
Default Temp
218 is not hot.
Old Jun 13, 2007 | 04:37 AM
Vesa's Avatar
Vesa
Originally Posted by clintwilson
218 is not hot.
its damn hot
Old Jun 14, 2007 | 10:20 PM
clintwilson
Default temp
IR guns can check beer temp.
Old Jun 14, 2007 | 11:02 PM
gator79's Avatar
gator79
come to think of it I never put one back because it was not quite cold enough
Old Jun 14, 2007 | 11:13 PM
dennisb's Avatar
dennisb
Interesting thought. I have a kegerator and would like to be able to get an accurate reading of the temp of the keg.
To is this to hot?
