2 bolt main
Old Jun 12, 2007 | 07:22 PM
hwt03's Avatar
hwt03
Cruising
Default 2 bolt main
is the engine in my 1980 really only a 2 bolt main? what was GM thinking.
its funny, but when I'm driving the vette, people wave and give you the right of way. when I'm in my ford truck they wave with one finger and cut you off.
Old Jun 12, 2007 | 07:28 PM
sdonnelly's Avatar
sdonnelly
I've heard a two bolt is good for around 400 hp, far more then your car came out with. So, I would assume they used those to save money.
Old Jun 12, 2007 | 07:53 PM
sperkins's Avatar
sperkins
I checked long ago and the concensus was that my 2-bolt 327 could handle up to 500hp.
Old Jun 12, 2007 | 08:27 PM
SmokinBBC's Avatar
SmokinBBC
My 70 454 is a 2 bolt main.
Old Jun 12, 2007 | 08:37 PM
ghoastrider1's Avatar
ghoastrider1
aint nothing wrong with a two bolter. Chevy made them from 55 and they did plenty of work without problems. 4 bolts dont add power,nor do they add to the looks. I doubt if they even add time to the service life of a normal engine.
Old Jun 12, 2007 | 08:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My 550HP small block is a 2 bolt
Old Jun 12, 2007 | 09:27 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
It's all about the money $$$$$.
Old Jun 12, 2007 | 10:07 PM
clintwilson's Avatar
clintwilson
Default 2 bolt main
1980 could be 2 or 4 bolt 350.
Old Jun 12, 2007 | 11:02 PM
79tnvette's Avatar
79tnvette
I believe the l82s were four bolts and the l48s were two bolt.
Old Jun 13, 2007 | 04:49 PM
markdtn's Avatar
markdtn
Unless you are making serious power 2-bolt is fine.
Old Jun 13, 2007 | 05:18 PM
OregonVette80's Avatar
OregonVette80
Correct. 1980 Bay-Bee!
Old Jun 13, 2007 | 05:27 PM
Thmprr's Avatar
Thmprr
I have built more than 150 SBC race engines over the last 30 yrs. I go out of my way to use 2 bolt blocks when building SBC, especially 400ci. For power more than 450hp, I would use ARP main studs, or if the engine is going for more than 550hp, I will fit splayed cap steel 4 bolt mains.
The stock 4 bolt outside bolts actually create a local weakness area in the block, on 400ci, it is not uncommon to see cracks through that area.
If its an 010 2 bolt block, and if anyone asks and says, hey has it got 4 bolt mains, just smile!
Old Jun 13, 2007 | 07:16 PM
bluegtp's Avatar
bluegtp
i built a 383 with my 2bolt l-48 motor.....runs like a champ....revs to 6500rpms just fine and I've run the mess out of it too.....ha, that's why my transmissions out of the car right now....
ryan
Old Jun 14, 2007 | 10:58 PM
clintwilson
Default 2 bolt main
If the # on the back of the block is 14010207 it could be either. straight out of the corvette by the numbers book. 1980 only.
Old Jun 15, 2007 | 09:03 AM
Jims79's Avatar
Jims79
most sbc are 2 bolts. I know a guy who drag races and only uses 2 bolt mains.
Old Jun 15, 2007 | 09:19 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
No issues with the 2-bolt except for road racing or any other activity that requires high rpm for a extended period of time..
Old Jun 15, 2007 | 11:20 PM
Thinpockets's Avatar
Thinpockets
Originally Posted by hwt03
. . . . only a 2 bolt main? what was GM thinking.
With 190 hp do you really need more than one?
To 2 bolt main
Old Jun 16, 2007 | 02:33 AM
FinnShark's Avatar
FinnShark
That's good to know! Thanks! I have almost 500hp out of 2-bolt and I am a bit scared how long my engine will last. Your comment made me feel a bit better...
Old Jun 16, 2007 | 03:04 AM
Ironcross's Avatar
Ironcross
Sneaky Pete Robinson won the Nationals with a supercharged 2 bolt Chevy AA dragster.. Most of the altereds and roadsters were chevy powered in both blown and un blown classes.. They were almost as good as the early Hemis, but not quite. I put a lot of very good chevies back on there trailers.
Ironcross's Avatar
Ironcross
