I painted my faded black shifter boot red. Gave it four light coats, and it turned out much better than I had expected.Don't be disappointed after the first couple coats.
Anybody respray their steering column? mine is all chipped up from the keys and I want to refinish it. Is the Interior dye the right stuff to use on this or is there something else that works on metal? The interior dye spray does not say anything about being good to use on metal, it just says it good for door panels, seats, plastic trim, and carpet.
I forgot about the steering column…I did that too with the spray can dye
It turns out much better than you expect…I started with one spot and ended up doing most of the interior
Prep and cleaning is the key. SEM is an excellent product available at many quality auto parts and auto paint supply stores. Our upholster has been using it for years.
I bought the liquid cans of it, and used an airbrush to lightly overspray the parts that needed a touchup. I never had much luck with spray cans and cover-ability!!!!
I just did mine last month. Turned out good. Mine was pitted and had the key marks on it so I sanded down really good before spraying the dye. I am going to find a small peice of black rubber and glue it where the keys rub so that they don't scratch it again.
I used the dupli-color vinyl & fabric spray from local parts store last week worked great. Came out looking brand new!!!!!!!
That's what I used to go from camel to black. Unfortunately I was not as careful as I should have been in putting the pieces back in and they are scratched in places. Need to figure out a way to do touch up.
I am considering spraying into a cup and using a paintbrush or a foam paint "brush" to dab on the scratches (not stroke it on). Suggestions?
