1969 miss- help!!
Old Jun 13, 2007 | 01:27 PM
US300hp's Avatar
US300hp
Default 1969 miss- help!!
I have a 69 vette with a 350. When it runs it has a feeling of a miss. They motor vibrates and the acceleration is not too good. It happens throughout the entire RPM range. It happens cold and hot. I have changed everything: plugs, wires, distributer cap, rotor, points, coil, set the dwell, set the timing, cleaned out the carburator, and still it does not run correctly. It starts OK and idles but there is that annoying feeling its not on all cylinders. It does not smoke or burn oil. It runs at a normal temperature. Any ideas would be appreciated, I've almost given up! Thanks!!
Old Jun 13, 2007 | 02:10 PM
pws69's Avatar
pws69
When was the last time the valves were adjusted?
Old Jun 13, 2007 | 02:59 PM
US300hp's Avatar
US300hp
Default 1969 miss
I don't know. I only got the car about 3 months ago. It seems odd that hydraulic lifters would need much adjusting.
Old Jun 13, 2007 | 03:06 PM
GD70's Avatar
GD70
You'd be surprised. Listen for tapping.
Old Jun 13, 2007 | 03:14 PM
US300hp's Avatar
US300hp
I don't think I heard any but I will check it out. Thanks for your input. Any other ideas if that is not the problem?
Old Jun 13, 2007 | 03:24 PM
1stC3Vette's Avatar
1stC3Vette
Did the car run fine after you made the changes to the plugs / wires, etc. or was it always happening?
Dino
Old Jun 13, 2007 | 03:54 PM
US300hp's Avatar
US300hp
Dino
It was always happening. Thats whats bugging me.
Old Jun 13, 2007 | 04:08 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
look for things that are out of balance.....start with the fan clutch....is it wobbling? are all the belts running straight?
and be sure to check the firing order....these cars run amazing well even if two wires are crossed
Old Jun 13, 2007 | 04:13 PM
Ed Blue 03's Avatar
Ed Blue 03
Not the first thing to check, but something to consider. The gear that went on the camshaft had a fiber coating to reduce noise. It will get worn out and put slack in the timing chain. Good luck.
Old Jun 13, 2007 | 04:16 PM
1stC3Vette's Avatar
1stC3Vette
I would recommend you do a compression test on each cylinder. This way, you can determine if everything is ok in the valve train / piston ring area.
Good luck,
Dino
Old Jun 13, 2007 | 04:51 PM
VettePower's Avatar
VettePower
This happened to me a long time ago. With me a push rod had wore a hole thru one of the rockers, making that cylander useless. The symptom was the same as yours.
missing all thru the rpm range, but at idle it was not real noticeable.
Old Jun 14, 2007 | 08:28 AM
pws69's Avatar
pws69
You are correct, they typically don't once they are set up. I am suggesting that they may not have been adjusted correctly. What you describe sounds like you may have one adjusted too tight. You should go through them all using the [running] procedure that is being discussed currently in the Tech section.
To 1969 miss- help!!
