would you drive it home?
Old Jun 14, 2007 | 10:28 PM
michael c. volpe's Avatar
michael c. volpe
damn........i'd say no.
i brought my first vette, about 1 1/2 hours away, and had it towed home.
i erred on the side of caution. i just didn't want any problems.
once i got it home, i had a mechanic give it the once over, i felt better about it.
maybe because it was my first vette, 25 year old car, and 134k, that helped me make up my mind.
*edit* jackass drivers on the garden state parkway played a bit in my thinking also.
Old Jun 14, 2007 | 10:41 PM
gator79's Avatar
gator79
well since you are flying there you do not have to many options. at first I was thinking no, but it could be ok, the part that scares me is only 350 miles in 6 months. you are getting ready to double that in one day. but what the heck go for it. I towed my 93 back from Florida because the part that scared me is being stranded in some town and at the mercy of some shop that knows nothing about your car. if you have a breakdown it may be cheaper at that point to rent a truck and trailer and tow it home the rest of the way. good luck
Old Jun 15, 2007 | 09:10 AM
Bangkok Dean's Avatar
Bangkok Dean
Go for it and if you have a problem on the way home give me a call and I will come and help you push it home.
Old Jun 15, 2007 | 09:46 AM
mrtroutjedi's Avatar
mrtroutjedi
Drive it! When I bought mine i drove it 5 hrs home with nothing more than a test drive and (Luckley) I got home fine . It was cold and I didn't have any heat but, It was the best drive ever. If it breaks down you will have a story you can laugh about years later.
Old Jun 15, 2007 | 10:44 AM
markbett's Avatar
markbett
I live in outside of Philadelphia, PA and bought mine out near Minneapolis, MN. A solid 2 day 20 hour drive. Flew out, drove it home. I also brought my brother to switch drivers and my tool box.
I think I was a little lucky, 20 year old tires, had to stop and get it aligned before we left Minne. The guy did a total restoration on it and when I got it home, I found a few bolts that had to be tightened that he missed. Great experience but my A$$ hurt for days.
Old Jun 15, 2007 | 11:41 AM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
I drove my 76 from Sacramento to Houston (1800 miles). When I picked it up I noticed the fan clutch was bad, the owner had tools with him and he put a new one on at his expense. I was a little nervous at first, but once I made the Texas line I figured worse case would be if it broke, I have it shipped back and I fly back.
Now all I do is keep adding stuff and spending money on it.
Old Jun 15, 2007 | 12:24 PM
timgman's Avatar
timgman
Default a few things..
I'd test drive it (with spirit) and after that let it run for a bit to see the cooling system in action. Good strong shifts, good oil pressure, good frame / birdcage, good rakes.... let it rock!!!!!!!!!!!!!
Old Jun 15, 2007 | 01:49 PM
ShinodaVette's Avatar
ShinodaVette
I guess it's a little late now for input since you were flying out last night but I would have said drive it too! I drove my '86 from Atlanta back to Tampa after flying out one way to get there. There's only one way to know for sure if it will make it or not; kind of like and adventure!
My '81 came out of Boca and I drove it back too but that's not quite as far. Sloppy steering on a rainy day was a lot of fun!
Old Jun 16, 2007 | 06:21 PM
Blue Seducer's Avatar
Blue Seducer
Default I made it back
Well I bought the vette and drove it home, 777 miles in 14 hours. Thanks for everyone's input. I will post some pics later. It has original show room new interior, original paint with slightly faded bumpers. Bonus, not just new front calipers, but all 4 with new lines & pads. No rust. The frame is still black. Original mufflers & pipes have slight surface rust. The only thing that didn't work was the cruise control. The power antenna worked until I got to Ocala. When I stopped for gas, I noticed that the motor was running but the antenna wasn't going down. I had to pull the fuse to stop the motor. I guess the plastic gear strip broke? So the rest of the trip was just the sound of the motor. After a full day of inspections, banks and the line at DMV, I got on the road out of Port St. Lucie at about 4pm (my time). I made plenty of stops to check fluid levels and to stretch my back. I pulled up at home this morning at 6am . The strange thing is that I got more waves, thumbs up and cool car comments, driving this c3 than I do in my c5. More later.....
Old Jun 16, 2007 | 06:34 PM
gator79's Avatar
gator79
glad you made it back with no problems you said your antenna broke in Ocala, that's where I picked up my '93. looks like one more Florida vette in LA, Florida sure has some nice roads
Old Jun 24, 2007 | 01:27 AM
Mark_Milner's Avatar
Mark_Milner
Glad to see you made it ok. I forgot to check back and see what happened.
Old Nov 5, 2007 | 09:31 AM
1973-ls4's Avatar
1973-ls4
Cruising
I purchased my 1973 bigblock coupe in Onalaska, Wisconsin and drove it to Miami, Florida in 1986. The previous owner changed the water pump and replaced the belts and hoses. I carried some hand tools and only needed it to use them once - when the A/C clutch seized up on the Florida Turnpike and I cut the belt.
Word of advice, the trip home is NOT the time to performance check the car. Obey all speed laws, check fluids frequently, and keep track of miles per gallon fuel consumption - it may be a sign of impending trouble if it suddenly becomes very inefficient (more inefficient?) Most of all, enjoy the ride!
Old Nov 5, 2007 | 09:44 AM
  #33
pbcanney's Avatar
pbcanney
One of the best stories I've ever read is by one of my web buddies who bought a 73 GTO in California and drove it home to Memphis . I recommend everyone read this.
It's 73 '1/2' pages with a miriad of twists and turns and period music optional.
He's as passionate about GTO's as most of us are about our Corvettes. After you circle from the last page to the start page again, be sure to click his email and give him a little feedback. It's truly a masterpiece of webliture.
here's the link:
Daves 1973 GTO Odyssey
Old Nov 5, 2007 | 09:49 AM
  #34
AirTrafficController's Avatar
Applies to most cars that have "evolved":
68 Impala "Cool"
1998 Impala "not so cool"
Old Nov 5, 2007 | 11:37 AM
  #35
ESU's Avatar
ESU
Glad you made it OK bro and glad you finally got your C3. What color did you get?? I know you were partial to blue?? You gonna love the 82, wasnt it great cruisin at 70 mph but only turnin 2000 rpms? Once you get squared away with the minor nuances look into getting the fuel pressure squared away. I learned alot from the crossfire vault guys and recently added a fuel pressure gauge under the hood and got the adjustment tool to bring the pressure up to 14psi. Supposedly will make a big difference in performance. Cant wait to see the pics,
Cory
Old Nov 5, 2007 | 11:38 AM
  #36
Stewart's74's Avatar
Stewart's74
I'd drive it!
oops..looks like youre home already
Old Nov 5, 2007 | 12:10 PM
  #37
Blue Seducer
Well it's been a while. Sorry I didn't get pics up sooner, but I have been busy having fun with this C3. Here's one. [IMG][/IMG]
To would you drive it home?
Old Nov 5, 2007 | 12:17 PM
  #38
Blue Seducer
Originally Posted by ESU
What color did you get?? I know you were partial to blue? Cant wait to see the pics,
Cory
Dark Blue Metalic, same as yours.
Old Nov 5, 2007 | 12:39 PM
  #39
ESU's Avatar
ESU
Excellent, now if we could just get them together for a photo op!!! There was a guy selling one on vette finders I think with like 3500 original miles but he wanted big money. Your car looks great, drive it safely and enjoy and dont forget to check out the crossfire vault for any related problems that may crop up.
Cory
Old Nov 5, 2007 | 12:50 PM
  #40
GD70's Avatar
GD70
"The strange thing is that I got more waves, thumbs up and cool car comments, driving this c3 than I do in my c5."
WHY AM I NOT SURPRISED!
You did well. It's beautiful. Have fun and congratulations.
Glenn
