69 STILL doesn't run right
Old Jun 14, 2007 | 05:04 PM
US300hp's Avatar
US300hp
Default 69 STILL doesn't run right
Thanks to all who have contributed info to my problem, but it didn't go away!! To review:
I have changed Plugs,wires, cap, rotor, points, coil.
I have set the dwell, timing, adjusted all my valves,
cleaned out my carburetor, checked for vacuum leaks, looked for misaligned belts,and checked the fan for wobble. The car does not smoke, burn oil, or overheat. It starts right up hot or cold.
It is a stock 1969 vette 350 cu/ 350 hp motor, no A/C convertible.
The problem is it has a vibration all through the RPM range. It seems to me like some kind of miss (not using all cylinders??). It never goes away!! I know it could be a major engine problem but it doesn't seem that bad. Could the distributor be off by maybe one gear and the car still run? Thats my next guess. Any other ideas? Thanks again for your help.
Old Jun 14, 2007 | 05:12 PM
Durango_Boy's Avatar
Durango_Boy
Have you checked the balancer? If it separates it could possibly cause a vibration.
Old Jun 14, 2007 | 05:28 PM
Ironcross's Avatar
Ironcross
Not to upset the apple cart, but vibrations as described are also characteristic of a main bearing problem.
Old Jun 14, 2007 | 05:30 PM
US300hp's Avatar
US300hp
That looks good. This seems like more of a "Running" problem not so much just a vibration. The car has poor acceleration along with the vibration.
Durango_Boy
How is the oil pressure?
Old Jun 14, 2007 | 05:32 PM
US300hp's Avatar
US300hp
oil pressure is good. Gauge acts correctly.
(YIKES not a main bearing!!)
Old Jun 14, 2007 | 05:35 PM
Durango_Boy
Can you describe the procedure you used to time your engine?
Old Jun 14, 2007 | 05:38 PM
US300hp's Avatar
US300hp
Good question!! Basically I was moving the distributor back and forth to see if it would affect the vibration. Whether I was advancing or retarding the timing it didn't seem to make a difference. The engine reacted the way you would expect but the infamous miss/vibration did not get affected.
Old Jun 14, 2007 | 09:12 PM
BigBlockk's Avatar
BigBlockk
Which cylinder is missing? If you don't know which one it is start pulling plug wires one at a time until you get one that doesn't drop the idle RPM. You may be able to at least zero in on one cylinder this way. If you do find that it is one cylinder pull the valve cover to make sure the valve train is still functioning.
This could be a flat cam lobe, pulled through rocker arm, bent pusher rod, pulled rocker stud, broken valve spring or sticking lifter.
BigBlockk
Later.....
Old Jun 14, 2007 | 09:23 PM
thoyer's Avatar
thoyer
Do a compression test.
Old Jun 14, 2007 | 09:46 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
no the distributor is not off one tooth, your timing would correct for that......however if the timing chain jumped......you did verify the firing order and that all plug wires are where they should be?
Old Jun 15, 2007 | 09:02 AM
US300hp's Avatar
US300hp
The firing order is correct and all wires are in order.
Old Jun 15, 2007 | 09:04 AM
US300hp's Avatar
US300hp
BigBlockk
Later.....
I'll check by pulling wires, but I've already adjusted the valves and all components are OK.
Old Jun 15, 2007 | 03:47 PM
Kyle69-71 BBs's Avatar
Kyle69-71 BBs
Lets see, bad plug,bad wire,vac advance on dist not conected,points not gapped right,timing set wrong,vacum leaks,bad motor mount....
Look to make sure you got all your vac lines on the carb right,and the dist. vac connected.
Did you time it with the vac advance connected or disconnected?
Incorrect plug gap or points gap..?
trash in carb..
The trick with these tune ups is to fire the car after each job.
If the car starts running like crap then you know what it was you just did.I have been though this many times. Just start looking at each area and cross them off one at a time.Dont mess with new things if you can help it, the more things you mess with the longer the list of maybe s become. Good luck.
If you are unsure what to do next just pm me I can shoot you a phone # maybe I can help.
To 69 STILL doesn't run right
