Headlight Failure
Old Jun 15, 2007 | 08:18 AM
Thmprr's Avatar
Thmprr
Default Headlight Failure
The other night we were going on a cruise run, and the headlights went bright then out altogether. I thought it must be a relay failure, then I realized i had relays on both high and low beam.
Turns out I blew all 4 lamps. Sent it to the auto electrician, he found that it was a faulty alternator voltage control unit, replaced the bulbs and the voltage control unit so alls sweet.
Thought I would post this in case it happened to anyone else.
Old Jun 15, 2007 | 09:04 AM
SIXFOOTER's Avatar
SIXFOOTER
Yep, that can happen. Did he or you also check the battery connections? If the battery connection or the fuse link that feeds the circuit that the alternator #2 pin is connected to is intermittant or opens up, the alternator will go to full voltage, which is what yours did.
Old Jun 16, 2007 | 08:23 AM
Thmprr's Avatar
Thmprr
Yep, the fuse link had gone as well, battery connection were ok, it's scary when you suddenly encounter total darkness, as it was for us as we live in a rural area.
To Headlight Failure
