Bad or Wrong C-3 vacuum diagram-Take Note
I just verified mine. The original and my new replacement part are assembled as you suggest is the correct way. However my new part has no numbers on it. I used a marker and identified #2 as closer to the pull **** (Top left of Speedo) and # 3 as farther away.
Is there a schematic that shows these by using the #2 / #3 designations? My AIM (1969) shows #2 as Yellow Stripe and the #3 as Light Blue. Page J286 UPC 12 B11
The #2 gets the hose that has vacuum on it with the engine running.
(The #3 port dumps the vacuum from the hose going to the headlights when you pull the **** out and remains wide open just like a vacuum leak until you push the **** back in,then the #2 is connected to the #3.)
The vac diagrams LOOK complicated but really are not.
At the HL switch there are only 2 nipples to think about.
When the HL sw is pushed in the 2 nipples are connected and merely pass the vacuum though the hoses.
When the HL switch is pulled out the nipple closest to the **** (port #2 marked on switch) must seal off the hose connected to it-the hose connected should be the vacuum source coming from the manifold.
The nipple furthest from the **** (#3) will simply open up to create a leak-this leak will tell the HLs to open.
If the wrong hose ,the one coming from the manifold, is on port 3 it will hiss the entire time the HLs are on.
The pulldown works EXACTLY the same way and nipple location is the same.
How many grounds are there under the center console? One to the center console faceplate and one to the brace under the radio?
Last - my DocRebuild OooSoEeze says there is a Auxilary A/C Harness connection. What is that for?
Off the top of my head I think I can picture 7 ground sights.
left pillar,speedo,tach,console,power window at console,right pillar and the all elusive center cluster ground which is the center spade of the temp gauge connection. This is where IMO doc missed the boat , this ground site should have had a note emphasizing its importance.
Which of the 3 pages are you looking at for the Auxiliary connection ?
Hey Rog... ok - after pulling the console (again) - I found only one connector as we are discussing. That connector is under the Heater/AC control assembly and is a brown wire (although Doc Rebuild says its black). It must be the Auxillary RH Door Pillar Ground. I feel certain of this as it is in proper order according to the Doc's chart. I found it in the 1969 AIM on J346 (Item 6). I confirmed it ties into the dash harness just beside the black/grey wires for the Heater/AC bulb. However it does no say where it connects..
I do see the closely located ground for the console shifter plate.
Last - I cannot find the Auxillary A/C harness connector we speak of. I did trace it in DOc's OoSoEZ, and see it ties into the fuse block - NOT THE HARNESS.
All said - I think
the ground I was thinking of on the right pillar/kick panel area (and maybe you were thinking this one too) is maybe for the A/C harness????? If so - wonder why they call it the Aux RH Pillar Ground if it is located under the center console??? Since I have Vintage Air - I have no OEM A/C Harness.
If you don't want confusion dont read the following line :(because my aim shows the blue striped line (going to the override) to be connected to the port closest to the know lol) Regards,
Nick
Zip corrected their diagrams
The website Corvette101 refuses to correct their diagram so this will continue.
Of the 2 connectors I am trying to identify, I found only one.
It is the Auxillary A/C Harness connector. It is brown, is incoporated into the harness and is correct in color and location on OoSoEZ chart. I believe I found this connector as well in the 1969 AIM on J346 (Item 6). I confirmed it ties into the dash harness just beside the black/grey wires for the Heater/AC bulb.I also identified it on my old dash harness and confirmed by testing with a volt meter. By using my old A/C harness, OoSoEZ and the AIM, I now understand that the A/C harness initiates its wiring and power under the console area from that connector mentioned above.
However, I still cannot find the Auxillary RH Door Pillar Ground. I know it will be black as it is a ground. I checked my old harness and do not find it on it either. This ground connector should come out of the harness at or after the radio connector pigtail (according to OoSoEZ). My original radio pigtail/connector was cut off, so I was unable to assess whether the ground was part of the radio pigtail (like the dual wired ground on the console). But then I checked Lectric Limited's website and see the radio pigtail has no extra ground connection.
Can anyone show me where the Auxillary RH Door Pillar Ground connector comes out of the harness? Is this possibly an error on OoSoEZ?
And yes there are some errors on the diagrams.
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
