T Top Trim
Old Jun 16, 2007 | 02:00 PM
SULLY_PA's Avatar
SULLY_PA
Default T Top Trim
Does anybody have any idea how to get the trim off the t tops of my 79'?
Old Jun 16, 2007 | 05:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The stainless pieces? Make sure all of the screws and/or rivets are removed, then gently pry it off with a screwdriver.
Old Jun 16, 2007 | 07:51 PM
SULLY_PA's Avatar
SULLY_PA
There black and outline the top.....Didnt see any rivets ...I'll check again...thanks
Old Jun 16, 2007 | 07:59 PM
early shark's Avatar
early shark
I know from experience on '68 thru '72 tops. I believe the front stainless piece above the windshield is a crimped on piece, insert like an ice pick into the open end and gently begin to pry outward until you get the end starting to come loose and then gently continue prying it off. The small joint piece has a rivet under the weatherstripping that needs to be drilled out. The long piece above the side window has both screws to remove the weatherstripping and then rivets to drill out to remove stainless trim, should be 3 rivets.
Old Jun 16, 2007 | 10:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Old Jun 17, 2007 | 10:20 AM
SULLY_PA's Avatar
SULLY_PA
got it thanks
To T Top Trim
