Engine Numbers, Simple questions.
Here is what I was told about the current engine in the vette.
"The casting number is 3970010 and the engine suffix is ML07800."
What exactly does this mean?
It is a GM crate motor.
Another thing I have been trying to figure out. L82 models had 290 hp, right? On my center console there is a little, I don't know what you would call it, but it's right under the shifter and the a/c controls. It says, 350 Cubic Inches, 285 LBS FT. TORQUE, 9.0:1 COMP RATIO. The last refers to the rear end gears, correct? My only question is it says 285 Torque. I always though horse power and torque were generally the same. Why would the numbers be different? I know those numbers refer to the original engine and not the current one, which is why I am hoping some one can help me further identify the current engine.
I know it's some pretty basic stuff, but I am just learning and a bit turned around at the moment.
Horsepower = (torque*RPM)/5252
So at 5252 rpm, the horsepower will equal the torque, but only at that spot.
Hopefully someone else can give you more info on the block.
I have to disagree 010 blocks came in 2 or 4 bolt mains.
I don't know for sure about if that number changed for different years...but I know for sure that is the rating for a '77 model.
As far as the L-82 vs L-48...the L-48 reaches its peak h.p. (180) at lower rpms and actually gives more torque at lower rpms than the L-82.
Someone please correct me if I am showing my ignorance...lol
I am sorry I don't know where my brain went.
