Speedometer problems 1977
Old Jun 17, 2007 | 02:31 PM
clight77's Avatar
clight77
Default Speedometer problems 1977
Hi i just started having speedometer problems with my 1977.
It has TH350 i thought it was the driven gear but it looks fine, the drive gear is green 7 tooth and it looks fine also.
I put a cordless drill on the tranny cable end and the speedometer does work.
I was going to order both gears but have run into a snag, the driven gear off of the cable is a red 21 tooth and from what i can see that gear is for a 4 speed standard and that seems odd to me, any ideas ?
Old Jun 17, 2007 | 03:54 PM
Duke94's Avatar
Duke94
21 tooth red is correct for a auto. What rear end ratio do you have?
Here is the chart:
Old Jun 17, 2007 | 04:05 PM
clight77's Avatar
clight77
3.08 gear ratio
Also my drive gear is green 7 or 9 teeth from what i can see of it.
Old Apr 3, 2009 | 04:37 PM
clight77's Avatar
clight77
The speedometer in my 1977 vette TH350 is still jumping around last summer i replaced the cables and gears but it did not help.
I heard some where there is a clip that locks the drive gear or worm gear in the tranny tailshaft from slipping.
Does anyone know what that would be called or where to find it ?
I think the worm gear on the tailshaft of the tranny is slipping..
Thank you
Old Apr 3, 2009 | 04:43 PM
VettePower's Avatar
VettePower
Thank you
It can also be your cruise control transducer causing it to bounce.
Old Apr 3, 2009 | 05:04 PM
clight77's Avatar
clight77
If that were the case it should bounce when running it with the cordless driver also, i would think.
Correct ?
Thanks for the reply
Old Apr 3, 2009 | 05:09 PM
Ganey's Avatar
Ganey
If you have cruise, it's probably the cruise control transducer. Disconnect at the transducer & spin the cable to speedo.
Bypass the transducer: Possible a 86-88 MC SS lower cable may connect & screw to the upper cable.
Old Apr 3, 2009 | 05:15 PM
clight77's Avatar
clight77
Hi
Maybe i am over looking something
I ran a cordless driver to the cable where it connects to the tranny and no bounce,so it must be running through the transducer from there ? Right ?
Thanks and be patient . LOL
Old Apr 3, 2009 | 05:33 PM
Ganey's Avatar
Ganey
"The speedometer in my 1977 vette TH350 is still jumping around last summer i replaced the cables and gears but it did not help."
Yes, if driving the cable from the trans., then it goes through the transducer (W/ cruise) to speedo. Most likely the jumping is from the transducer.
Old Apr 3, 2009 | 05:39 PM
clight77's Avatar
clight77
Should i replace it, or is it serviceable ?
Old Apr 3, 2009 | 05:56 PM
Ganey's Avatar
Ganey
You could try a topic on repairing the transducer- nothing to lose.
It's between the fender & brake MC.
Old Apr 3, 2009 | 07:45 PM
clight77's Avatar
clight77
Great thanks for the replies
Old Jun 11, 2011 | 01:42 AM
clight77's Avatar
clight77
Hi have not logged in for a couple of years,have not driven my 77 vette in as many years.
I have a question? Can cruise control work with the transmission part of the cable removed,as mine does,just bought a transducer and speedo still does not work,bought new cable and driven gear previously.
I jacked the car up and put it in gear and cable from tranny does not spin,so i gather it is the drive gear in tranny now.
But how can cruise control work if this is the case?
To Speedometer problems 1977
