Air Conditioning Question...
Old Jun 18, 2007 | 10:59 AM
dgr72vette's Avatar
dgr72vette
Default Air Conditioning Question...
Am replacing the main air compressor hose on my '72 and would like to know which (picture please) valve to use to refill with R134A....
The can says large diameter hose but the former owner has a blue cap on the smaller hose! ?????? Any help would be appreciated!
Old Jun 18, 2007 | 11:52 AM
hosspowerinc's Avatar
hosspowerinc
The large diameter hose is the low side the the small is the high side. This is always the case and disregard the cap color. It means nothing. You will have to have adapter fittings to add 134a. Hopefully you replaced the drier as well and added the proper about of pag oil. Make sure you pull a nice long vacuum to check for leaks and to get all the moisture out.
Old Jun 18, 2007 | 02:06 PM
ZR1Blex's Avatar
ZR1Blex
If it isn't too late, I would discourage you from converting to 134 refridgerant. I previously looked into doing this and was told by a few Corvette specialist shops that these conversions do not work very well and even when they do the a/c won't be very cold. I had them repair and refill my a/c with R12, which works so well it can freeze me out of the '79.
Also, the last I heard it has been recently discovered that 134 is worse for the environment than r12 is.
Old Jun 18, 2007 | 03:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ZR1Blex
...it has been recently discovered that 134 is worse for the environment than r12 is.
Old Jun 18, 2007 | 04:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Those "Corvette specialist shops" obviously either didn't have a clue how to properly set up a 134a system or just wanted to gouge you for the R12.
Old Jun 18, 2007 | 05:18 PM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Old Jun 18, 2007 | 07:33 PM
dgr72vette's Avatar
dgr72vette
Car was already converted by previous and air worked fine (not ice cold but good enough to cool you off. I accidentally broke one of the metal tubes coming from the compressor. Am replacing that whole main hose and just want to know where to fill the r134, the hole closest to the fender or the inside one.
Old Jun 18, 2007 | 07:36 PM
hosspowerinc
Im not trying to be rude but if you dont know which fitting to use, you probably need to take it to a professional.
Old Jun 18, 2007 | 08:01 PM
dgr72vette's Avatar
dgr72vette
Thanks...was just trying to save a few bucks by doing it myself
Forget It
Old Jun 18, 2007 | 09:36 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
hosspowerinc is not trying to be a smart$*#. There is a lot more to charging the system then just pouring freon into it. Do you have a vacuum pump? Do you know how much freon to put into the system and how to bypass the low pressure switch in order to get the compressor to kick in if necessary? Do you have a set of guages so that you can see what the high side reading is? Do you know what the high and low side readings should be?
To Air Conditioning Question...
