Body Mount Question
Also on numerous posts there was a list of things that needed to be disconnected to lift the body up but in other posts it stated that just the negative battery cable had to be disconnected. I am just looking to lift the body up enough one side at a time to remove the old rubber and put in new screws and poly bushings. It looks like i will only have to lift it up about an inch or so to get it changed out.
I have had the bolts soaking in a rust breaker for the past week. If anyone happens to know a good spot to find a how-to preferably with some example photos it would be greatly appreciated. Plan to keep searching until I find a good tutorial before i undertake a project like this.
Edit: Forgot to mention that i decided to change out all body mounts since they all look pretty rusted. Pray for me, hehe
There's still a lot that has to be loosened or removed so check the list. Some things that come to mind: brake lines at the booster, rag joint, clutch linkage, radiator core at the frame, radiator fan/shroud, and most the bumper parts, front and rear.
But doing it your way, you may could do without disconnecting most cables and wiring.
Good luck and budget all weekend.
If the brake lines are coiled for stretch ... maybe leave them,
but gotta disconnect the steering coupler at least ... and bumper
to frame mounts.
Unfortunately, I lost many of my resto pics when I had a disk crash.
Show me a link to the post you refer to and I will try to dig up the pics to match.
I got your PM .. still looking for PDF to send (not my PDF, but shows some stuff).
PS - I did a full body-off ... not the 2-3 inch deal.
to frame mounts.
NHVette, the post i kept going back to was at:
http://forums.corvetteforum.com/show...ht=body+mounts
It was originally a post by MYBAD79 with a link to a pdf on your website. If you happen to stumble upon it, that would be great.
Thanks once again guys. I will try to get as many photos as possible for hopefully other people to use during this little expirement.
to frame mounts.
I found the copy that I downloaded back in the day.
http://kens71.com/docs/Body_mounts_small_file.pdf
enjoy
KO
Fritzy ... emailed you to send the PDF, but no reply yet.
I have many pics. Here is one that is sure to save some time,
but if the #4 cage nut is rusted solid, you might have some extra work ahead.
I pulled the cage nuts at #4 and dropped a bolt from the top with big washers.
Here is a zip file with a bunch of #4 reinforcement pics.:
http://webpages.charter.net/davekimt...ges/4mount.zip
You may also get the strange and irresistable desire to clean and restore
the metal parts ... "while I'm at it".
Any steel you see restored in my vette is etched, POR15, and Krylon top coat.
Pretty sure the retainer piece is only accessible with the front fenders removed.
Well, looks like you can get it throught the foot vent ... if not blocked off (AC cars).
I actually blocked both mine off to keep warm air entering from the engine area.
I had the firewall removed, also.
Materials used to mount are polyurethane adhesive, 3/16 stainless pop rivets,
and backer washers are recommended for the rivets.
Might want to warn the wife that some parts might need to come inside to dry by the wood stove.
