T-Tops won't stop leaking
Old Jun 22, 2007 | 12:14 PM
spike1360's Avatar
spike1360
Default T-Tops won't stop leaking
My 75 has leaked during every hard rain since I've gotten it, even when I keep it covered. I don't have a garage to put it in so I need to try and fix the leaking. The weatherstripping still feels soft and is uncracked. Should I replace it anyway. Has anyone else had leaking problems.
Old Jun 22, 2007 | 12:31 PM
corvetteload's Avatar
corvetteload
Are you sure its the tops?!?!?!?!?! Between your center "T" stainless piece and the windshield is the windshield molding, this is seperate from the "T" piece. Most leaks occur in this gap, and they follow the windshield frame to either the rearview mirror or down the sides and will actually drip from the bottom of the side dash pieces. I removed all the molding on my 69 and completely filled that top channel with GOOP, then reinstalled the "T" and the windshield top molding. I believe you can just remove the top molding and fill that front area in and you would be surprised at the difference, I did that to my POS 75. Or I just forced it in between the 2 pieces, I don't remember, but it stopped the rearview mirror drip I had.....................B
Old Jun 22, 2007 | 01:41 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
You might try loosening the mounting hardware and trying to line everything up to see if you can close the gaps.
Old Jun 22, 2007 | 09:22 PM
spike1360's Avatar
spike1360
Thanks guys, will try it.
Old Jun 22, 2007 | 10:11 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Check out this post I started years ago. I don't think GM figured it out till the C6. Then again I can't confirm that yet either.
http://forums.corvetteforum.com/show...highlight=leak
Old Jun 22, 2007 | 10:25 PM
spike1360's Avatar
spike1360
That's demoralizing, but I agree with that thread. Wouldn't trade my corvette for...well...most other cars.
Old Jun 22, 2007 | 10:38 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
If it leaks it's GM.. .. My '99 Z28 T-tops don't leak..... maybe a drop here and there but that's it... I'm beginning to wonder........
Old Jun 22, 2007 | 10:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It's a 30+ year old car. Are you sure the weatherstrip isn't just shot?
Old Jun 22, 2007 | 11:03 PM
spike1360's Avatar
spike1360
Yeah. I checked. I was really hoping that would be it. My carpet's soaked every other week.
Old Jun 22, 2007 | 11:31 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
3 out of 4 of my corvettes have had leaks. my 71 was like a swimming pool when it would rain. my 75 is almost as bad but that is getting fixed in the very very near future and my 2000frc leaked too. my z06 is the only one that has not leaked yet. i am keeping my fingers crossed. i replaced all the weather stripping on the 75 and it still leaked. i will have to check the trim like what was mentioned earlier in the thread while i am replacing the weather stripping this time. good info here.
Old Jun 22, 2007 | 11:38 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My 77 has always been a bit drippy, but the weatherstrip has been a wreck for the entire time I've been involved with the car.
Get a bright flashlight, and shine it around the t-top weatherstrip from the inside. Look from the outside, and if you see light leakage, you have a water leak.
Old Jun 23, 2007 | 12:40 AM
randommj's Avatar
randommj
ive never seen a C3 coup that didnt leak
Miles
Old Jun 23, 2007 | 09:44 AM
Tuxblacray's Avatar
Tuxblacray
Are you sure the cowl drains aren't clogged? If they are it can force the water inside to the carpet.
You can easily blow these out with an air compressor.
Old Jun 23, 2007 | 10:13 AM
spike1360's Avatar
spike1360
Honestly, I don't know what or where the cowl drains are? Could you direct me.
Old Jun 25, 2007 | 06:17 AM
Tuxblacray's Avatar
Tuxblacray
Sorry I just returned... I will try to get a pic in the next few days to help you. If not I will pull my cover off of Tux and get you one. ( My cowl area sport an aftermarket cover to hide the hideous stuff GM left open showing the wiper arms and tons of GM sealant.
Old Jun 25, 2007 | 08:28 AM
corvetteload
"If not I will pull my cover off of Tux and get you one"
Leak or no leak, I hope you don't have a name for your car like this guy!!! I call mine the 69 or 75, or the "POS", depending on my mood.
Old Jun 27, 2007 | 07:36 PM
kansas123's Avatar
kansas123
I thought my T-Tops were the source of my leak so I painfully replaced the weatherstrip on both. Looks like crap and did not solve the problem. The problem turned out to be right in front of me: a gap between the windshield trim and the "I" trim had sealant that had hardened and/or went missing. I put black marine sealer in there and no more leak. Wish I hadn't messed with those seals, now I will have to redo them someday. What a cluster...............
To T-Tops won't stop leaking
Old Jun 27, 2007 | 07:47 PM
rajsid's Avatar
rajsid
Why do you have to drive the Vette in the rain ?
Old Jun 27, 2007 | 08:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What happened? T-top weatherstrip is pretty easy to replace.
Old Jun 27, 2007 | 08:32 PM
spike1360's Avatar
spike1360
I bought my vette as a driver. it's my one and only car. i can't afford to buy another one and let the vette sit. if i could i would.
