1980 A Arm bushings
Old Jun 23, 2007 | 04:06 PM
c3corvetteman's Avatar
c3corvetteman
Default 1980 A Arm bushings
AAARRRRGGGHHHH! Bought the complete suspension rebuild with the urethane bushings. So far so good, rear worked out great, started on the front. A arm bushings are original, and they absolutely refuse to come out. I don't have a big press, trying to use an air chisel, good god, any ideas? Or do I bite the bullet and pay a shop? Shoestring hotrodding on a budget, but if I must, just tell me.
Oh, and thanks in advance for not flaming me.
Old Jun 23, 2007 | 05:00 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I used a propane torch to burn out the rubber. Then I used a sawzall on the sleeve while the shaft was still in . Just cut enough to break through the sleeve.
Old Jun 23, 2007 | 06:25 PM
dannyman's Avatar
dannyman
I've torched them out and I've also drilled them out.(multiple holes)
Old Jun 23, 2007 | 08:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I used a cold chisel and a 2lb. drill hammer and knocked the bushings and shells out as a unit. I tried cutting, burning, drilling, etc. on one, it took forever. With the chisel, it took about 5-10 minutes per bushing.
Old Jun 24, 2007 | 12:27 AM
c3corvetteman
Default Probably next...
Buddy of mine talked about burning them out, and I have tried the drill method, which did work for two. Just an amazingly tough part of the project. Can't wait to feel how much better it drives when they are finally replaced. Thanks to all of you for your ideas! You are all so helpful. T
Old Jun 24, 2007 | 11:45 AM
hwcoop's Avatar
hwcoop
I used a hole saw to cut the rubber out and 2 minutes with the air chisel to get the shells off. Then it was time for
Old Jun 24, 2007 | 12:54 PM
Timmijoe's Avatar
Timmijoe
a local garage took an air chisel to mine and got one off...I thought that tecnique was crazy and took the rest to a person who had a press and pressed them out and then pressed the new ones in...
thats how Chiltons recommended to do it.
Old Jun 24, 2007 | 04:25 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That technique wasn't crazy, it was just fine. Someone who doesn't know what they're doing with a press will mangle your arms.
Old Jun 24, 2007 | 06:37 PM
Bowtyeguy's Avatar
Bowtyeguy
If the arms out it takes 5 minutes with a air chisel. I have done 100 of them and NEVER had a problem, some were more stubborn but all came out within 5 minutes. Use a bushing driver and hammer and a vice , some white grease and they go in the same way. You have to go around the outsides of the case to seperate them from the arm, after years they rust together. Once loose use the chisel from the front lip and work your way around and it will pop right out. You can shoot it with penetrating oil if you want but clean it before putting new bushings in,.
Old Jun 28, 2007 | 09:38 AM
Timmijoe's Avatar
Timmijoe
Well I'm glad to know that chiseling them out is common practice...the first time I saw it done scared the &%$$ out of me I thought what the &%$$ is he doing
it just seemed like bubba work to me...good luck
Old Jun 28, 2007 | 09:42 AM
Frank_833's Avatar
Frank_833
If you are in the DFW area you can come by and use my press...
Old Jun 28, 2007 | 11:18 AM
spedaleden's Avatar
spedaleden
[QUOTE=c3corvetteman;1560797927]AAARRRRGGGHHHH! Bought the complete suspension rebuild with the urethane bushings.
When I rebuilt mine, I was going to use urethane bushings, after talking to restoration and hot rod builders. They suggested rubber and to use urethane on sway bars. They told me the urethane will make the car tighter but the ride will be like a truck. Most guys eventually go back to rubber. Now maybe your going to run this on the track but if you are running on the street, you may not be happy.
Just a heads up
Old Jun 28, 2007 | 02:11 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
[QUOTE=spedaleden;1560862573]
Just a heads up
I had poly bushings in my old Talon's suspension. It didn't ride like a truck, it was just nice and tight. I'm not sure who "most guys" are, but I've only seen a handful of posts about switching back to rubber.
To 1980 A Arm bushings
