tach reading
Old Jun 27, 2007 | 05:25 PM
SizzleChest's Avatar
SizzleChest
Default tach reading
with an L82, 4spd, 3:70 rearend, what should my tach be showing @ 60MPH?
Old Jun 27, 2007 | 09:59 PM
chris75stingray's Avatar
chris75stingray
you'll also need to know tire hieght. do a search and there are sites were you type in your info and it will tell you the rpm's
Old Jun 28, 2007 | 11:51 AM
avner's Avatar
avner
Check this link:
http://www.differentials.com/calc.html
Old Jun 28, 2007 | 01:26 PM
C3 4ME's Avatar
C3 4ME
I have exactly the same combo on my 79, and my tach doesn't read right, so I'll check out that site, thanks for the link.
Old Jul 8, 2007 | 10:52 PM
SizzleChest
that can't be right. i have 255/60r15s and my tach shows 3000RPM @ 60MPH. according to that calculator, it should be 2763 - that's a big difference.
Old Jul 9, 2007 | 05:30 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
These electronic tachs are not all that accurate based upon my observations. I've repaired a few tach boards for forum members and always try and calibrate them the best I can when they are fixed. The ones I've done have been off as much as 4-500 RPM in the midrange, right about where you are measuring at. The middle seems to be the worse spot as far as accuracy goes.
The most recent one I did was reading about 3400 at a 3000 rpm input. You can trim them a little bit but the circuit itself does not lend itself to accurate linear operation and can only be adjusted at one end or the other. I've found no way to get the original circuit accurate across the complete rpm range.
If you want to be sure, just beg, borrow or ste....... ah acquire a dwell/tach, timing light w/a tach or similar that get's it's signal from the #1 plug vs using the distributor tach output and compare what it reads to the stock tach. I am willing to bet that most C3 electronic tachs will be off by a fair amount at some point on the dial.
FWIW. Good Luck!
To tach reading
