'70 L46 Gas???
Old Jun 28, 2007 | 01:44 AM
Cosmo Kramer's Avatar
Cosmo Kramer
Default '70 L46 Gas???
What gas are you all running in your '70 L46 Vette? If it's leaded premium, are you adding a lead additive to today's unleaded premium? Unfortunately, race fuel is not available in my location.
For the last 38 years (I'm 48,) I've wanted a '70 Vette. Well, through Hemming's Motor News, I found a '70 L46 Vette that I really like and am considering purchasing. Assuming I purchase the car, it will be my fifth Corvette ('78 Silver Ann. Edition, '96 CE Coupe, '98 Vert. and my current ride '05 Vert..) The car will be a "trophy car" and will not be used on a daily basis (that's what the '05 is for.)
Old Jun 28, 2007 | 07:38 AM
Gordonm's Avatar
Gordonm
The lead is not going to be the issue. It is the octane you need to worry about. You are running a 11:1 motor providing nothing has been changed. You are going to have to back down the timing or find some octane boost or mix in some race gas. Leaded fuels have not been around my area for years and it has not been a problem. It does not sound like you are going to put on many miles so the absence of lead won't be a real problem. My dad had a L46 Vette and used to mix in 1 gallon of race gas to a fill up of premium and that stopped any pinging problems.
Old Jun 28, 2007 | 09:19 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The need for lead is a long perpetuated myth. All of my older high compression Vettes including a 65 L79 350 horse and a 68 427/390 all run fine on unleaded pump gas, 93 Octane with no additives and no hardened valve seats. They don't ping or overheat and I have not retarded the timing. The engine in the 65 was last re-built in 87 and I have had no issues other than the plugs burn cleaner on unleaded than they used to on leaded.
Old Jun 28, 2007 | 09:27 AM
monza_man's Avatar
monza_man
I throw in a can of lead aditive everytime I fill up and use 93 octane on my '69 L-46. Never had a problem with pinging, no need for race fuel IMO.
Old Jun 28, 2007 | 10:54 AM
Dave J's Avatar
Dave J
I've had my "70 L46 coupe for 18 years now. Started out feeling I should boost the gas with whatever I could find. After a short while, I found out 93 Octane worked just fine. 76,000 miles, original 11:1 compression, no pinging, no problems.
Old Jun 28, 2007 | 01:34 PM
Cosmo Kramer
Everybody.........Thanks for your replies. So, the leaded gas issue is a myth - that's good to know. On the other hand, with 11:1 compression (the car is bone stock with 36K miles on the ticker) octane is more of the issue. It's easy to find 91 & 92 octane (that's what I put in the '05) at the local gas stations, but finding 93 is a bit tougher. Who sells 93 at the pumps? Also, if you're adding an octane booster, what brands do you recommend and where is a good place to buy it (online?)
I'm getting very close to purchasing the car. It's a '70 L46 Laguna Gray Metallic / Black coupe. The VIN is 194370s413558. Other than a T&T steering wheel (N37,) the only options are performance options: L46, M21 & ZQ9. I've hired a professional inspector to inspect the car and, assuming his report is good, it's a "done deal."
Old Jun 28, 2007 | 01:54 PM
dennis's Avatar
dennis
Had mine since 73 and have tinkered with fuel since leaded went by by.
(1)You can use aviation fuel if you have access. My 70 L-46 runs best on that.
(2)Next best thing... get yourself some max lead 2000 additive. You can locate venders over at the NCRS board for it.
(3)Where I'm at now... Sunoco ultra thats it, runs great. However, I did block the heat crossover the last time I replaced the intake gaskets. That blocking of the heat under the carb cured any pinging I may have had. Downside is it takes longer to warm the choke.
BTW... I run 12 dgrees vacuum advance, blocked the TCS.
Old Jun 28, 2007 | 01:59 PM
Gordonm's Avatar
Gordonm
Where are you guys finding 93 octane. I can find 91 and on occasion find 92 but not 93.
Old Jun 28, 2007 | 02:12 PM
monza_man's Avatar
monza_man
Its everywhere in NC and it was always everywhere in NY when I used to live there too.
Old Jun 28, 2007 | 04:41 PM
dennis's Avatar
dennis
Sunoco ultra..... any station on the turnpike. Got it in Mt Holley on 206 near Corvette paramedics for 2.92
Old Jun 28, 2007 | 04:52 PM
dennis's Avatar
dennis
[QUOTE
It's a '70 L46 Laguna Gray Metallic / Black coupe. The VIN is 194370s413558. Other than a T&T steering wheel (N37,) the only options are performance options: L46, M21 & ZQ9.QUOTE]
To lazy to look it up whats ZQ9?
Old Jun 28, 2007 | 05:03 PM
FKING1's Avatar
FKING1
I run Sunoco 94 unleaded in my 70 L46 with no lead additive. Not necessary to add the lead. Was running 110 leaded mixed with regular but at $6.00 a gallon and my gas mileage. forget it.
Old Jun 28, 2007 | 10:54 PM
Cosmo Kramer
Originally Posted by dennis
[QUOTE
ZQ9 is the Axel, Positraction rear, performance ratio (3:55.) – A whopping $12.65 option.
The car passed inspection so it's a "Done Deal." The inspector specializes in Corvettes and all the numbers match. Appearance is excellent and other than the engine temp. gauge not working (a cracked sending unit wire) the car is in perfect mechanical condition (even the clock works.) Obviously, the car is 37 years old and as such (being bone stock and un-restored) the paint has a few rock chips. Delivery should be mid July. I'll take some pictures and post them on the forum.
Old Jun 28, 2007 | 11:02 PM
Cosmo Kramer
For the time being, here are a few of the seller's pictures:
Old Jun 29, 2007 | 08:26 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Nice looking coupe Good luck with it
Old Jun 29, 2007 | 08:31 PM
fugawi's Avatar
fugawi
you can always go to your local airport ,and get 100lowlead avgas. add one gallon to a fillup. gets you the octain you need with a bit of lead for lubrication. this is what i did for my L-46. works great...
To '70 L46 Gas???
