low vacuum??
Old Jun 28, 2007 | 01:51 PM
andylmusic76's Avatar
andylmusic76
Default low vacuum??
what should the vacuum be for a sbc? my car is probably at like 12-13 hg at idle, but i was told it needs to be atleast 20 hg. if it needs to be higher, how can i tune my engine to get more vacuum?
Old Jun 28, 2007 | 03:28 PM
kevinator80's Avatar
kevinator80
A stock engine should be higher. I can't say how high, but maybe 15-20"? Your cam, timing and carb settings all effect vacuum. Give some details and you will get more answers.
Mine is at 12-13 with a xe268 and 1.6 rockers, timing at 17 initial.
Old Jun 28, 2007 | 04:29 PM
1stC3Vette's Avatar
1stC3Vette
I just checked mine yesterday. It showed 17 - 18hg at idle. Timing is set at 12 initial. I tried to adjust it higher, but could not get anymore.
Good luck,
Dino
Old Jun 28, 2007 | 04:32 PM
andylmusic76
Good luck,
Dino
i'm not sure what my timing is set at, but here's what i have.
stock l-82 heads 1.94"/1.50"
224/234 cam
performer intake and 600 cfm carb
the shortblock itself is a crate engine gm goodwrench 270 hp
Old Jun 28, 2007 | 05:01 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is what we always called the old Fart Chart! Hope this helps you.
Engine Vacuum Old Timer Chart!
Steady 17-22 in hg = normal
Low but steady = late ignition, valve timing or low compression.
Very low = Vacuum leak.
Needle fluctuates as RPM’s Increase. = ignition miss, blown cylinder head gasket, leaking valve or weak spring.
Gradual drop at idle = excessive back pressure in exhaust system.
Intermitted fluctuation at idle = engine miss or sticking valve.
Drifting needle = improper idle mix, adjustment, carbs not synchronized, or minor intake leak.
High but steady = early ignition timing.
Old Jun 28, 2007 | 05:58 PM
Duke94's Avatar
Duke94
Mine is 17"-18" at cruise speed.
Old Jun 28, 2007 | 06:39 PM
andylmusic76
mine is around 20-21 at cruising speeds. i was just concerned about my vacuum at idle...
Old Jun 28, 2007 | 07:33 PM
Duke94's Avatar
Duke94
My idle is about 19" as I recall.
Old Jun 28, 2007 | 08:01 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
[QUOTE=kevinator80;1560871989]A stock engine should be higher. I can't say how high, but maybe 15-20"? Your cam, timing and carb settings all effect vacuum. Give some details and you will get more answers.
Mine is at 12-13 with a xe268 and 1.6 rockers, timing at 17 initial.[/QUOTE]
Identical numbers....same camshaft......454!
To low vacuum??
