Oil pressure question
Old Jun 29, 2007 | 09:01 AM
Jims79's Avatar
Jims79
Default Oil pressure question
My old L48 held the oil pressure at 20lbs then would go up to 40 & 50lbs. My new motor drops to 10lbs at idle or below and runs at 40lbs steady.
Does this sound normal to you guys. I've never seen oil pressure drop so low at idle. I'm running 10w30 VR-1 for the first 500 mile break-in would that make the difference. On my old L48 I ran 10w40 GTX
Old Jun 29, 2007 | 09:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I agree 10lbs is on the low side, but you might be okay. I would keep an eye on it just the same.
Old Jun 29, 2007 | 09:26 AM
weimer20's Avatar
weimer20
10 psi per 1000 rpm is something that I've heard floating around as being adequate.
Old Jun 29, 2007 | 09:31 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Are you sure its not the sending unit? seems a littel on the low side to me
I am guessing you dont have the mechanical Oil pressure guage? One thing I did was to buy a cheepo generic guage, (like 14 bucks) hook it up and compare the results to my stock guage. Once i replaced the lines, they read dead on and I drive with much more confidence
worth a try
tim
To Oil pressure question
