Painting the engine
i did the EXACT paint job your talking about, (painting w/o removing from the engine bay) and it all looks better 10 fold, just find some heat resistant primer and paint and go to town
before
after
this is a 74 L48
Miles
Just get your paint, tape, and masking material and have some laquer thinner to remove overspray. You should be able to do a nice job in a few hours. Might want to pull the valve covers to give you better access to the intake manifold and that way you can do a better job on the covers as well.
If you are running stock exhaust manifolds you may want to use the dressing to give them the freshly cast look.
I've done a lot of enigines/engine bays without the engine out and you can really make them look nice. I've mostly used rattle can and brush for hard to reach areas. I might have to try using a brush more sometime as Sevnt6 did.
Having a nicely detailed engine can pay off. I sold a '69 Camaro and the guy popped the hood and said "I'll take it" Didn't even drive it first!
Make sure the surface is clean before painting too.
If you have any rough surfaces, say on your inner fenderwells, you might want to sand a little first if you're going to paint them.
Have some gloss Black and semi-flat Black on hand for the fan shroud, brake vacuum canister ec. as well as your primary engine color. Might want to pick up some cast Gray for the altenator if you want to hit it too.
You might as well get high heat paint for the block ec but I've used regular enamel plenty too.
Painting the engine/compartment is pretty forgiving. If something goes wrong you can usually just wipe it off with thinner and start over.
If you've got colored ignition wires you can wipe them with the thinner to remove grease.
Just do it in sections and be carefull not to put your hand in wet paint or that's a redo. (something I've done time or two
My oil pan looks like crap but from above...........
I am thinking about starting to paint the top of my engine the next day that i have off.
As you can see from the pic, there is alot of rust and dirt that i will have to clean off. Im planning on just the top of the engine. Do you think a brake cleaner will clean all that off?
Oh and SEVENT6, where did you get that chrome distributor cover? it looks like it even threads your spark plug wires under neath the exhaust manifold
I'd check the exhaust manifold dressing it can be had for less than $20 and makes the exhaust look near new.
http://cgi.ebay.com/ebaymotors/MANIF...QQcmdZViewItem
Heres when I did my latest one (pontiac) 1st picture is just the primer coat.
I bought mine new & I'm the only one who's ever put plugs in it..........
