Hydroboost/powersteering, non Corvette
Old Jul 1, 2007 | 09:47 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Hydroboost/powersteering, non Corvette
I have a Hydroboost on an RV, it stops fine the first stop or two then the pedal gets very hard.
I've replaced the booster, that helped.
I redone the brakes with good pads, also helps.
Only thing left is the power steering pump?
Would the pump loose pressure when it warms up?
The power steering BTW feels just fine...
Keith
My 69 Corvette in paint jail
my '29 Dodge basket case
Old Jul 1, 2007 | 11:06 PM
Durango_Boy's Avatar
Durango_Boy
It sounds to me like the Hydro unit itself is malfunctioning. Maybe, and I don't know the full anatomy, but there may be a valve or something to bleed off excess pressure past what the accumulator holds. If that bleed off isn't happening then it may be keeping the system pressurized.
My first guess would be you need a new unit.
Old Jul 2, 2007 | 12:50 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
He already replaced the unit
Old Jul 2, 2007 | 07:16 AM
Durango_Boy
That doesn't mean he replaced it with a good one. Did you have any suggestions for him?
Old Jul 2, 2007 | 08:29 AM
SIXFOOTER's Avatar
SIXFOOTER
Well, I am no expert on these things yet. But as I recall the gas canister is supposed to supply brake power for about 3 applications. So, if your pedal gets hard after 2 or 3 applications, it sounds like your not getting High Pressure to the booster (if it works). If you shut it down, give it a few minutes and fire it up again does it stop ok 2 or 3 more times? Is there a kink in a line? Return line from the booster is good, not stopped up?
Old Jul 2, 2007 | 11:01 AM
427V8's Avatar
427V8
DB, Ugh, I hope it's not a bad booster, that would be the suck. It's not the easiest vehicle to work on...
sixfooter,
Thats a good test.
I'm also thinking I should put a pressure gauge in it and see if it changes over time.
but what pressure should it be?
Old Jul 2, 2007 | 11:09 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's a good question. I haven't seen a whole lot on Hydroboost test procedures. There has to be some way to check these things out...
Old Jul 2, 2007 | 11:48 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I believe this place can either test or rebuild them
http://www.fleetpride.com/fp_p/index.html
They also do drive shafts
They've done a few of mine for my truck
Old Jul 2, 2007 | 10:07 PM
chris75stingray's Avatar
chris75stingray
does your power steering feel like its working good?
To Hydroboost/powersteering, non Corvette
