Air Horns
Old Jul 3, 2007 | 11:39 PM
Ajaxxx's Avatar
Ajaxxx
Cruising
Default Air Horns
I bought a set of air horns and was wondering if I can just plug it into the existing horn wires with an in line fuse? Also. What's the best way to get to the horn itself without removing the front end?
Old Jul 3, 2007 | 11:42 PM
SIXFOOTER's Avatar
SIXFOOTER
Air horns only require a valve, small current. existing circuit will work
Old Jul 3, 2007 | 11:45 PM
Big2Bird's Avatar
Big2Bird
That's not always true.
Old Jul 3, 2007 | 11:54 PM
SIXFOOTER's Avatar
SIXFOOTER
yea, ok. Air horns are operated by air, that has to be furnished from a blower/compressor unit of some sort which may overload existing horn circuit.
Why would you want air horns?
Old Jul 4, 2007 | 09:51 AM
Durango_Boy's Avatar
Durango_Boy
Maybe he spends a lot of time down at the docks.
You can get non-air horns that are just as loud if that's the reason.
Old Jul 4, 2007 | 10:00 AM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
THESE are air horns. You'd have to find somewhere to put the tank/compressor, probably in the back. Would really turn some heads hooked to the alarm circuits tho
http://cgi.ebay.com/ebaymotors/Hamme...9359QQtcZphoto
Old Jul 4, 2007 | 10:10 AM
Jims79's Avatar
Jims79
Why would you want air horns?[/QUOTE]
why?
Old Jul 4, 2007 | 10:49 AM
79vett's Avatar
79vett
It's a redneck thang. I like the charge one myself
Old Jul 4, 2007 | 03:55 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I just picked up some extra-loud standard type horns at the parts store. My Delco originals weren't working.
The air horns should have an instruction sheet indicating how they plug in. Without knowing the brand and the details of the units, it's hard to say for sure.
Old Jul 4, 2007 | 10:13 PM
Ajaxxx's Avatar
Ajaxxx
Cruising
Thanks for all the input. This air horn kit comes with a mini compressor. It is all self-contained. I am not sure if it will overload my circuit. The instructions say it is safe for a plug in type connection.
Old Jul 4, 2007 | 10:18 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
How 'bout one of those "Dukes of Hazzard" horns that play Dixie?
Old Jul 4, 2007 | 10:24 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
why?[/QUOTE]
I had a set installed on a Triumph TR4 back in the late 60's. I had them set up with an auxiliary switch so I could still use the standard horns. I only used the air horns if I was really pizzed at some a-hole on the road. Scared the sh*t out of them, they would be looking all around for an 18 wheeler.
Old Jul 5, 2007 | 01:17 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I want one of the old Plymouth Roadrunner "meep meep" horns on an auxiliary circuit...
To Air Horns
