Help to ID a Part #
Old Jul 4, 2007 | 10:43 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Default Help to ID a Part #
Can anyone ID GM Part # 496346 Gr. 3.075. If so, would you be able to tell the year (s) this # was used on the part, which i believe is a 68, 69 exhaust spout. I've seem several different #s for this part, thanks!
Happy 4th!!!!!!!!
Old Jul 4, 2007 | 01:36 PM
DZRick's Avatar
DZRick
Hopefully someone else will help you first but I've got a book around here somewhere that may help.
Rick
Old Jul 4, 2007 | 01:52 PM
71 Green 454's Avatar
71 Green 454
Happy 4th!!!!!!!!
http://fiedlerh.home.att.net/exhaust.htm
The '74 Grand Am tip (left) is essentially the same as a '68-'69 Corvette (right) chrome tip. These are readily available from Corvette restoration suppliers. The only difference is the position of the crimping slots where the clamp installs, which you can't see unless you crawl under the car and look closely. Other than that, they are identical.
Pontiac part numbers
74 all A (except Station Wagon) qty 2 496346
This part number was superceded by 3952742
Note that 73 and 74 tailpipes are different due to the differences in chrome tips.
Old Jul 4, 2007 | 02:20 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Thanks, can you explain a little more about the difference in the crimping slots? Thanks, john
Old Jul 4, 2007 | 02:23 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
also, i was unable to click on that link you sent. is there a site i can go to?
Old Jul 4, 2007 | 03:47 PM
71 Green 454
Opens for me, anyway, I think the crimping slot position refers to the position in reference to the mounting position on the muffler. Like 3 o'clock and 9 o'clock.
Maybe someone else will clarify this part number.
Old Jul 5, 2007 | 01:38 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
I got the link open, does this mean these are correct for a Potiac only and not a Corvette?
Old Jul 5, 2007 | 03:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
http://www.zip-products.com/Zip/prod...4261F37B48B5E3
To Help to ID a Part #
