i recently completely redid my brakes with a deluxe kit from Zip-Products in Virginia. Its been about 4 months and the brakes work great, but they're still squealing really bad. The kit says it came with organic pads. Has anyone tried those anti-squeal products with any luck?
Some people use Disc Brake Quiet on the back of the disc pads before putting them in the caliper. Sometimes it helps.
I use it every time and have not had a problem. I even added the anti-squeak kit that you can buy. You can just place some cut tubing at the end of each brake pad to limit the movement of the pad.
