How should I lower the front?
Jul 4, 2007 | 04:32 PM
From: 90% of all Fords are still on the road.....the other 10% actually made it home!
I definitely want to lower my car before I do anything else to it. Obviously the rear is just a matter of longer bolts,.....but those of you who lowered your cars, what method did you use for lowering the front?
Cut the stock springs? If so, how much?
Replace with aftermarket lowering springs? If so, where did you get them?
Thanks!
Jul 4, 2007 | 05:52 PM
I did what most people do I cut the stock springs. Becareful not to take to much off. I cut 3/4 loop off of mine, but a lot of people take one full loop off with out problems.
Jul 4, 2007 | 05:54 PM
Jul 4, 2007 | 06:08 PM
Hey, I really like that black vette!!!! I have VBP springs in mine and I also cut about 3/4 of a loop out. Vette sat way to high
460 Springs
Jul 4, 2007 | 06:27 PM
Right on, thanks a lot for the advice!!
And those are some really "NICE" Vettes by the way!
I'll no doubt have to cut a full coil then,......I'm just not someone who likes wheel gap.
Also, what are you guys running for tire sizes? I haven't decided whether I want to go with 275/60's or 295/50's.
Jul 4, 2007 | 06:36 PM
Quote:
Originally Posted by
str8upchevy
I'll no doubt have to cut a full spring then,......I'm just not someone who likes wheel gap.
I'm stock 255/60/15
Jul 4, 2007 | 06:47 PM
spedaleden
I'm stock 255/60/15
I probably better go with the 275/60's then. 295's might be too much on an 8" rim.
Jul 4, 2007 | 06:56 PM
str8upchevy
Take some pics, would love to see it when finished
Jul 4, 2007 | 09:14 PM
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
get stock replacement springs ($50) and cut them.
Jul 4, 2007 | 09:20 PM
St. Jude Donor '09
Juggy, you still find time for other post?
I figgered you'd be busy doin' the color commentary in the pizzin' matches
Jul 4, 2007 | 09:28 PM
St. Jude Donor '09
yellow 72
I can multi-task.
Jul 4, 2007 | 09:29 PM
I just hit a switch and lower it.
Jul 4, 2007 | 09:30 PM
St. Jude Donor '07
I cut aftermarkert lowering springs
str8upchevy
Thanks!
nice vett!!!
Jul 4, 2007 | 09:31 PM
St. Jude Donor '09
lowrod vette
Details?
Jul 4, 2007 | 09:48 PM
Jughead
Details?
well my car has a hydraulic system 2 pumps and 2 batteries. It goes up and down to the ground but still has the handling of a vett because it still has custom springs and shocks on the front and back. The also goes side to side like a lowrider thats whey it call a lowrod half hotrod half lowrider.
Jul 4, 2007 | 09:50 PM
Jughead
Details?
Any pics or install details?
What parts did you use? DETAILS?!?!
Jul 4, 2007 | 09:53 PM
St. Jude Donor '07
Jul 4, 2007 | 09:56 PM
Yellow73SB
Pics?
sorry I`m not setup for pic yet.
Jul 4, 2007 | 09:58 PM
Hydros are ok but an air bag system is better there is less maintanance no oil or batteries to charge.
