1980 w/ am, fm, cb radio Antenna?
I have a 1980 with a factory am,fm,cb radio, but the Antenna is missing. If possible I would like to install the factory correct antenna.
I attempted to install a after market am fm power Antenna but the plug is not the same (the car has a female plug that takes a rectanglure shaped pin) and I can not find a adapter.
Help and advice needed, Thanks
Do you want AM/FM or AM/FM/CB. Companys like Corvette Central, Mid America carry both. When you get the one with CB you will receive an adapter box. This box will have one input from antenna and two outputs. One will go to radio and other to CB. It was also give you a setting to adjust the antenna to the CB. This will all be stated in the instructions.
Is the lead your looking at by the antenna or radio. If it is the antenna you need to run new wires to the radio.
