Two Harmonic Balancers,..which is better
Old Jul 6, 2007 | 01:10 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Two Harmonic Balancers,..which is better
I have two stock harmonic balancers from 454's. I'm needing to use one on a project. Is there a way to tell which of the two is in better shape other than visual inspection?
Please advise and thanks!
Old Jul 8, 2007 | 12:56 AM
73, Dark Blue 454
Anybody?
Old Jul 8, 2007 | 02:03 AM
Z-man's Avatar
Z-man
Probably not - at least without some kind of laboratory. I'd go with the one that has newer looking paint...
Old Jul 8, 2007 | 05:17 AM
rpoL98's Avatar
rpoL98
in general, look at the condition of the rubber.
also, look at where the timing cover seal rides, you don't want a groove there from the previous timing cover seal.
if one's a heavier weight, that's usually better (i.e. HD vs std duty), assuming that they're both balanced to 454, not 427. I'm not sure if 454 balancers came in different tunes, i.e. truck, passenger, high-perf.
obviously, you don't want stripped threads for the crank pulley mounting bolts.
look for evidence that it's been bubba'd with a prior hammer install.
and then of course the paint.
To Two Harmonic Balancers,..which is better
