Pressure Testing A/C Condenser
Old Jul 6, 2007 | 08:57 PM
jwhouse's Avatar
jwhouse
Cruising
Default Pressure Testing A/C Condenser
1970 Conv. with SB & 4-SP
I am replacing the Radiator, Support, etc. and want to pressure test the A/C Condenser which is now out of the car. I am looking for a way to seal up one opening and either pull a vacuum or pressure test through the other opening. However, theA/C O-Ring types of Male and Female connectors make it difficult to find the mate such that I can used my A/C hose connection.
I have tried the normal hardware stores, and even Grainger could not offer a recommended solution.
Suggestions are welcome.
Jack H.
Old Jul 6, 2007 | 09:01 PM
vetteaddic's Avatar
vetteaddic
I just cover one end up with a finger and blow,or suck.
really!
Old Jul 6, 2007 | 09:13 PM
jcswm's Avatar
jcswm
really!
That's funny what if it only leaks at 250psi or more???
If your using R134a a new condenser designed for R134a will make your ac work better
some Radiator shops can pressure test condensers out of the car..... I'd break out the Yellow pages & ask around
Old Jul 7, 2007 | 12:18 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Well blow or suck really hard then!
Old Jul 7, 2007 | 12:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Maybe a shop that services vehicle A/Cs could pressure test it for you.
Old Jul 7, 2007 | 03:57 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I did a pressure test using a very simple and cheap tools, look at my A/C rebuild pages :
http://forums.corvetteforum.com/show....php?t=1726044
Hamad
To Pressure Testing A/C Condenser
