Adding a shoulder belt to a 68 vert
http://www.ecklers.com/product.asp?p...3&dept_id=1707
http://forums.corvetteforum.com/show....php?t=1707559
If you look at their pic, they show the retractor mounted on top of the wheelwell. That's a good spot for it, but that's not the factory spot for '68-9. They had the belt mounted to the vertical inner wall of the weelwell and not the flat top surface. Mount a horizontal retractor to a vertical wall and things won't work that well.
So you have the hardware for a factory belt, but that kit uses the later mounting point.
What to do? There are a few options.
You can bolt a hefty L-shaped bracket to the vertical wall and then mount the retractor to the horizontal part of the bracket (if that makes sense)
*or*
You can replace the seat belt reinforcement with a new one with the hole & nut on the upper horizontal surface
*or*
You can drill a new hole in the top wall, put a nut on the bottom side and mount the retractor on the top flat surface. If originality matters, drilling holes and installing incorrect brackets to the body probably don't fit well into your plan, so the adapter-bracket that I mentioned first is the way to go.
As for belts, there are some options there as well.
The Eckler belts
REAR seat belts from a '93+ Camaro/Firebird (search for Camaro Belt in the archives and you'll find a lot of threads)
Original equipment or repro original belts ($$$!!!!!!)
*Edit*
Looks like Paul67 used an Ecklers kit for his car. If that kit contains a retractor that's designed for vertical installation, it would be a good fit for a '68.
If you remove either rear wheel you can see the bracket riveted to the body just above the frame rail roughly in the center of the wheel opening. The bracket itself is L-shaped, about 4" front to back and around 3" tall & wide. There is a nut welded to the bracket that the bolt would screw into.
If you pull back the carpet from the wheelwells, you can see the inside of the bracket and the rivets that hold it to the fiberlass and maybe the hole that the belt bolt goes through.
My '69 vert had the mounting plates in place, even though it was not factory equipped with shoulder belts.A batch of parts had some nice shoulder belts, same color and date as my interior, bolted right on.
My brackets were rusted beyond use, and I didn't have the stock belts anyway, so I had the bracket holes glassed over and bought a set of generic belts to use.
With the Eckler's belts, I had to redrill the mounting hole for the retractor bolt, and used the supplied mounting plate, but you shouldn't have that problem.
Here's a few pics of the system mounted.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]This pic shows the top of the Eckler's mounting bracket peeking up above the frame.
I'm happy with the belts.
Retractor.
Retractor and seat belt guide.
I replaced the generic chrome buckles with GM.
Full setup.
paul67 - also looks good, I assume the bracket that holds the belt to the seat top was already on the seat.
I've got allot of work to do to get my car as clean looking as you guy's cars.
After I got the wheels off I could see the bracket and I was able to feel the threaded hole on the bracket behind the frame
.I'm ordering the belts tonight before the sale ends. Maybe after I get them installed I'll stop getting that funny feeling in my front teeth every time I hope in for a ride
Found that I didn't need them
When I did my belts, I hammered a new (thicker) bracket out of sheet steel and drilled a hole in the top side of the bracket for the Camaro belts.
