Dip Stick Tube
Old Jul 10, 2007 | 02:55 PM
Richard Cooper's Avatar
Richard Cooper
Default Dip Stick Tube
How do I remove the dip stick tube from my 81? Is it just pressed in? Thanks.
Old Jul 10, 2007 | 03:19 PM
SIXFOOTER's Avatar
SIXFOOTER
Its just pressed in and there is a tab bolted to the AIR tube I think. Get hold of it at the bottom with vice grips and wiggle it loose, but don't crush it
Old Jul 10, 2007 | 04:32 PM
Vette-4-Life's Avatar
Vette-4-Life
On my 80 there are 2 bolts that hold it in. One at top is near Valve Cover bolt. The one at bottom bolts to the block. I disconnected the battery and dropped the starter to easily get to it.
Old Jul 10, 2007 | 05:15 PM
Red 69's Avatar
Red 69
A 75 engine I have apart is similar to my 69 engine in that the D-stick tube has a double flared end that comes up from underneith. The flared end fits in a recession in the block along the pan rail and is held in place by the oil pan. There is only one way to get it out, and that is to drop the pan. On removing it, the tube comes very close to hitting the outside bolt on the second main cap in front of the oil filter. Once you drop the pan and gasket the tube will slide right out. If the 80 model is different then this isn't much help.
To Dip Stick Tube
